Question about Microwave Ovens
Replacing light bulb
The light bulb blew in my microwave and I can't get it out of the socket. It actually "blew" out and remnants of the metal are left in the socket. Tried everything. Any suggestions?
  • plunkpeach Jan 04, 2008
    I have the same problem on BOTH lights...can't get the base out.
Well on a regular light bulb socket - the suggestion was to take a potato and cut one end of it and wedge it on to take it off I personally think that is too messy not only that it wouldn't work for a microwave. First off unplug the microwave, now what I have done to take the base of the bulbs out is use a pair of needle nose pliers, open the pliers inside the base and gently apply pressure with the pliers inside the base and attempt to turn the base as if you were to simply unscrew the light bulb. Also what I have done before - with the same concept use a flat head screw driver and apply pressure towards the direction of unsrewing the lightbulb. MAKE SURE you do either gently because if you are not gentle with it you can damage your socket.
Posted on Mar 04, 2009
Remove the screws on the bottom of the unit and the panel drops. You can then remove one screw on the actual bulb holder and use plyers to spin it out. Make sure you disconnect the power.
Posted on Dec 16, 2007
This is an over the stove microwave. Need help replacing the light bulbs on the bottom of the microwave.
Disconnect the power and get a flat bladed screw driver to remove some of the bulb base away from the socket. Insert long nose pliers into the area created and turn base counterclockwise to remove.
Nov 21, 2015 | Microwave Ovens
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Stovetop lamp sockets very brittle and are disintegrating.
    In effect (given the unit is wired correctly) without insulation on the socket, you have an exposed neutral wire in your oven -- this is certainly not as dangerous as an exposed hot wire, but does present risks. I recommend replacing the light sockets -- you'll sleep and cook a lot better.
    Apr 23, 2009 | GE JVM1660 Microwave Oven
    Cooktop Light / Night light
    It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
    Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
    Bulb replacement
    WAIT!!! Before you just take the lamp cover off and try to replace the bulb that way, which would MAKE SENSE!!!, stop! All you'll do is snap the bulb off, leaving the metal screwy end of the bulb in the socket. Believe me - it happened to me. Twice.
    The only way to ensure that you'll be able to get the entire bulb out, because the only way you can actually SEE what you're doing, is to remove the bottom cover of the microwave. It's about 6 screws along the underneath surface of the unit. After removing the screws, the front of the cover will hang down and the rear will stay nested in a groove at the back. At this point, you'll be able to see the backs of the light sockets. Remove the two screws on either side of the sockets, and you can gently pull the bulbs out of the housing so you can actually see and work with them.
    Chances are, the bulbs have been GLUED into the sockets with silicone, which GE says it does to prevent moisture from getting into the sockets. Right. Then why is it that the replacement lamps work just fine without being glued in?! Anyway - GE actually instructs in the manual to "run a knife around the edge of the socket" to break the silicone seal. Hmmm..Sounds safe to me.
    So, after you've eliminated the silicone one way or another, just gently unscrew the lamp like you would any other.
    Trust me - you do not want to try to remove the lamps without removing the bottom cover. Oh, yeah - most importantly, unplug the microwave first! Good luck.
    Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Light socket is dead on my Maytag
    Yes, this is caused by not disconnecting the microwave from the power line when removing or installing a bulb or by the filaments shorting when the bulb blows. This is a problem with the control panel assembly, which we repair nationwide for $39.95. If you or a friend decide to send it to us, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
    Apr 01, 2007 | Maytag MMV4205 Microwave Oven
    Lights under the microwave won't turn off
    The problem is in the control board of the microwave. We repair these circuit boards nationwide for this problem for only $32.50. For more information you can do a search on Yahoo.com (not Google) for: microwave circuit repair It's a good idea to also send a copy of the technical note sheet from inside the oven when you send the assembly in for repair. This problem is caused when the bulbs are disconnected (or blow apart from) the sockets while the power is on. Power should always be disconnected before replacing bulbs, but sometimes they just fail on their own and short, causing them to "blow" like yours did. Also, be sure to avoid cheap bulbs, as we feel they have less chance of shorting and may hold up better.
    Dec 02, 2006 | Frigidaire FMV145K Microwave Oven
    Surface lights
    I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
    Sep 05, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    216 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
