Question about York Exercise & Fitness
I have a Adonis 616 can tell me where I would find the fuse? it was working fine moved it inside & no go
I have a Adonis 616 and want to know can I put the tradmill mat flat , not on a slight incline
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 27, 2016 | Exercise & Fitness
Does Kenwood VR-616 have phono input?
Yes over AUX-ilary with an riaa-preamplifier inbetween if moving magnet or moving coil if a phono is used ceramic / crystal phono element is used it can used without any pre amp
http://manual.kenwood.com/files/B60-5228-00.pdf
Nov 17, 2016 | Kenwood VR-616 Receiver
Wiring for Adonis desk mic to midland 8001
http://www.adonis.ne.jp/e-desktop.html click the PDF link for the mic you have. 1 audio, 2 shield, 3 receive, 4 transmit
Sep 09, 2014 | Radio Communications
Adonis 616 treadmill
will be better purcharse a new one. go to www.fitnessrepairparts.com
God bless you
Oct 14, 2013 | Exercise & Fitness
How do I permanently disengage the brake-transaxle shift interlock on a '97 malibu? The fuse and brake lights work fine. Do I take off the console and disconnect something?
It will be in your engine compartment. It will be a black box, pull the lid on it. On the inside cover of the lid it will tell you what each fuse is for. Find the fuse that says something to do with rear brake lights. When you replace the fuse make sure it it the exact same size, like replace a 5amp fuse with another 5 amp fuse. Also when you look on the inside cover of the fuse box lid there should be a couple empty spaces with fuses in them, these are spare fuses for your car. You can use one of these but just make sure to replace it.
Oct 12, 2012 | 1997 Chevrolet Malibu
Morning, I have Adonis 616, approx 8 years, love it, used a lot. Just last week it has started to slip a bit, belt is adj and lubricated it. This did not help, now when I start it, auto goes extremely...
Sorry sir this is a electronic problem
You must replace the Complete Controller board motor
has 3 controls: 1) Console board 2) Elevation motor 3) Main Motor.
Some IGTBs has been failed. Replace
Blessing
cuadra2016@yandex.com cell+whatsAPP:+50588611441
Treadmill How To Replace Control Board
Nov 16, 2017 | York Exercise & Fitness
I have a rockford fosgate ounch 325.1 (2004). I recently helped my parents move and took the sub and its sealed enclosure out of my 1994 Ford Explorer. The sub and amp worked until the move. After I...
it sounds like you have a short someplace. also, if you have a multimeter, check the voltage coming out of the speaker terminals of the amplifier. if the voltage is higher than 4 or 5 volts, the amp is probably bad.
Jan 10, 2011 | Car Audio & Video
When powered on protection light comes on
Protection usually means that there is a short some where. If it is inside the amp or external I couldn't tell you. You could check the fuse to make sure that isn't blown. I had a Memphis amp that blew both fuses and the protection light came on. I swapped out the fuses and worked fine, still works. If you have a multimeter set it to OHMs and check the resistance between the power terminals. It should be very high. If these things don't work then there is most likely something wrong with the amp or your power termination. I wasn't able to find a lot of information on this amp but if it has screw type terminals, did you use terminals. If you just put the wires in the terminals make sure there wasn't loose strands touching. I hope you can get this one.
-Andrew Hawkins
Mar 27, 2008 | Car Audio & Video
Sony xm-1002hx
If the fuse blows only after the remote voltage is applied, the output transistors have likely failed. Never use a fuse larger than the one recommended by the manufacturer. It can lead to more extensive damage (including damage to the circuit board) which will make the amp much more expensive to repair.
Sep 23, 2007 | Sony XM-1002HX Car Audio Amplifier
Exercise & Fitness Logo
219 people viewed this question
Top York Exercise & Fitness Experts
Mikee
William McDowell
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
