It sounds like your cameras are placed in the window. They will work fine during the day, but the reflection from the window will cause a blur at night. Try moving the cameras outside or away from the windows to get rid of the blur.
You need to go into the menu and go to the menu with a camera as the icon. Scroll until you find "IS mode". You can choose various settings but the best is "Continuous". That way, your camera always compensates for camera shake.
Horizontal may not be due to the CCD sensor. It can be due to the lens
itself. I swap lens from a non-working camera to replace the one with
horizontal lines. I found out that I was able to get the camera to work
to take great pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND
A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check
1 screen control on eht transformer is mituned
2 supply to screen of crt
3 supply to rgb video output is absent
4 connector loose
5 crt base loose
thanks
