Question about Panasonic KX TC1713 Cordless Phone
Handle Speaker phone stopped working
Can some one plz tell me how to fix this problem ...the speaker phone on the Panasonice KX TC1713 stopped working ..each time I hit the orange button ... it just doesnot do anything ....
I'll assume this is on the base station portion. You can try unplugging the power while the phone is in the base, wait a minute, then plug back in. If that has no effect, I'm afraid you either have a failure in the keypad or in the electronics. To diagnose a keypad failure in the base, you'll need to disassemble the base. You'll find each of the rubbery keys momentarily connects two traces on the keypad circuit board when you press a button. You may also find the keypad fouled with dirt, liquid, etc, which could be a likely cause of failure. You can try manually shorting the two traces where the SP/Phone button would press and see if you are able to activate the speakerphone/dialtone. If that works, then carefully clean the keyboard circuit board and the rubbery keys. If that does not work, I conclude you have a bad keyboard circuit board or other electronics in the phone are bad.
Posted on Jan 06, 2008
How to get speaker phone to work on Panansonic KX-DT343
Download the Panasonic KX-DT343 users manual and a pdf and there should be what you are looking for if not then there must be something funny going on with the menu system but why not have a look in the settings to see if the intercom setup is there but I think you will find out what you want from the KX-DT343.pdf file.
Dec 17, 2014 | Panasonic KX DT343-B Digital phone - Black
Speaker not working on panasonic kx-tga410
*** This phone is a POS ***
I've had three of four handsets stop giving audible feedback when a button is pushed, and 2 of 4 speakerphone stopped working.
Apr 03, 2012 | Lands Phones
The speaker phone on our panasonic KX-T7633 dosn't go loud enough. We are trying to hook up an external speaker, but when we plug it into the headphone jack we just get a buzzing noise. Is there a...
There should be a way to do that. 1st make sure speaker jack is fully inserted. If you still have same problem try normal headphones and see if there still is foreign hum- then if headphones work, check the size of both the jacks to see if there the same- you might just have wrong size jack. If that is not the problem the Impedance(ohm symbol) is probably wrong and the phone doesn't have enough power to drive your speaker.. Use a speaker with same Impedance, you might have to use a speaker with its own power supply to get appropiate volume. You could try your PC external speaker. I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-T7633 Corded Phone
I have a panasonic kx-tga271 handset. The speaker phone, the ringer and keypad noise do not work. Is it fixanle?
It could be the speaker. I have a handset with the same issue. The internal speaker which produces these sounds broke. If you can find a small speaker that fits inside, its an easy fix - - just take out the screw inside the battery compartment and carefully undo the plastic assembly. The speaker is held in place with a plastic anchor that twists off. There are two dots of solder which attach the wires that will have to be melted and resoldered on the replacement. Anyone thats handy can fix this. Look for a used handset for parts. You might also consider breaking apart a cheap set of headphones for the speaker. It won't be as loud, but at least the sound will be restored to some degree.
Oct 21, 2010 | Panasonic KX-TGA271 Cordless Expansion...
Nokia n73 speaker problem
if your speaker it sound broked when you listen music it need replacement, also check witch one is not working properly because n73 has 2 speakers
Aug 15, 2009 | Nokia N73 Cellular Phone
I need Help!! Plz Help Me!!!
The phones are probably not reaching the bottom of the connection where the MP3 is told to stop sending sound to the speaker.
Test with other phones.
If the problem persists, a firmware update would be a good idea.
Cheers
Jun 20, 2009 | Laser MP4-V970 MP3 Player
No dial tone - I have to dial using the speaker phone
sounds as if this phone will need to paired with the base again.
May 30, 2009 | Panasonic KX-TG5632 Phone
Panasonic KC-TC1713 cordless phone - Voicemail light stays on
You guys had the owner manual scanned on your web site so I just RTFM ;~).
To clear the voicemail light on the base unit, first press the Redial button on the phone, then hold down the Clear button on the phone for a few seconds. The light should go out.
Here's a tip: I wrote down the above instructions on a small piece of paper and taped them to the back of the phone. You could also tape the note on the inside the battery door.
Nov 24, 2008 | Panasonic KX TC1713 Cordless Phone
Caller ID Light Won't Stop Blinking on Base of KX TC1713 Phone
Solved this myself simply by scrolling through all the Caller ID entries from recent calls . . .
Mar 01, 2008 | Panasonic KX TC1713 Cordless Phone
Panasonic KX TC1713 Cordless Phone Logo
216 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
