Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Kohler 19 hp runs then backfires and stalls when heated up
Changed plug. mech said it was water in gas. he changed plug came back was blowing fuses. he said ignition wire was damaged. came back ran breifly same problem. he finds furniture stuffing from mice and says that was choking it from getting air. comes back a third time. cut 1/2 my lawn starts backfiring and dies. now wont run for more than 30 seconds. seems like a electrical problem to me can any one help?
  • 5,603 Answers
Check that the keyway for the flywheel to the crankshaft hasn't sheared. This is a common problem that throws timing very far off causing backfire and no-starts.
Posted on Nov 02, 2009
    Sergeant:
  • 417 Answers
It's more likely that you simply have a blown head gasket, that a sheared key on a riding mower, since the engine turns belts and is not directly attached to anything. Unless this genius mechanic removed the flywheel and reinstalled it with an air impact gun, in which case you probably DO have a sheared key, but id have a DIFFERENT shop do a compression, then a leak-down test.
Posted on Nov 21, 2013
Backfiring and missing
possible couple of things
low battery voltage by the system not charging enough
overheating component in the ignition system--coil failing when hot
engine overheating- no air flow around head and cylinder fins from dirt and rubbish
May 26, 2017 | Cars & Trucks
change the spark plugs.
Jan 06, 2014 | Cars & Trucks
Back firing and missing
Carberator take the sedum ate bowl of a clean the jets and every thing else with carb and choke cleaner also check that the float isn't stuck
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
1,611 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Wayne McNeil
Craig Butler
Craig Butler
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
