Question about Whirlpool LER5636P Electric Dryer
Whirlpool 4634eq1 will not turn on, timer will not move
    Sergeant:
    Champion:
  • 289 Answers
Your mod# is LER4634EQ1.if you can not turn the timer you nead to replace the timer.the part# for the timer is WPL3976569,it will run you about $100.00.
Posted on Dec 27, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Whirlpool dishwasher wont change cycles
wow, good move with the heating element. most folks don't know about how that relates. if that stuff is good, it must be the timer. or at least the small motor which turns the timer. good luck
Nov 07, 2009 | Whirlpool DU1055XTSD 24 in. Dishwasher
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
The deforst timer didn't work and got ice
Does the timer move? If you can, try rotating the timer to the defrost postion when the frigorator turns off and see if the defrost emement starts to heat up. If it doesn't then you could have a bad thermostate. easy to replace.
Jul 15, 2009 | Whirlpool ED5FTGX Side by Side...
When u turn on my gas whirlpool dryer it runs as normal. when u check on it a little later (on automatic dry) the timer has not moved, and the dryer has quit producing heat
Hi, the timer control the heating commands and, if its not moving(rotating), this will confirm timer failuer. replace it asap.
Jun 18, 2009 | Dryers
Whirlpool Gas Dryer Timer problem
OK, this timer is designed to spin in both directions and, if you have to advance this timer in any way to complete a cycle, you will need to replace this timer asap.
In most cases, the mechanism will fail, causing this non advancement stage(stalled timer mech).
replacing the timer will fix this issue.
Jun 01, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Ultimate Care II washer
If it will perform all of the functions if you turn your timer knob manually, I would open the console and check for any loose connections, although from your description your timer motor has gone bad (only availible as the whole timer) It can be purchased from online from the manufacture or from a local parts store.
Jun 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
199 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
