Question about Miele CVA4070 Coffee Maker
The brewed coffee does not flow freely from the spouts
The brewed coffee does not flow freely from the coffee spouts,it spills out all over and from the piece that slides up and down to adjust for cup size.
    Genius:
  • 1,689 Answers
There could be a buildup of minerals in the flow path of the coffee, or there could be bad seals, or there is some corrosion along the flow path.
With some investigation an experienced service person who is familiar with these coffee machines should be able to figure this out.
Jerry G.
Posted on Sep 25, 2009
No water flow
The hot water works, but when I run coffee, the water only goes into the used BIN, NOT the spouts. I can't get the water to go through to brew the coffee..
HELP
Feb 04, 2014 | Krups Orchestro 889 Espresso Machine
Hi, I have a Saeco Magic Comfort Plus. When I press the button to brew coffee, the coffee is spilling into the dregdrawer rather than thru the spout for the coffee. It's not water, but actual coffee is...
Hi
Sounds like your thumbscrew is getting stripped. Its the same for all the older machines.
http://www.fixya.com/support/t2927107-lttle_filter_disk_plastic_rod
If its only partially stripped it slips up and allows the water to enter the brew head pocket where the thumbscrew is and the spill over into the dredge drawer. Check the brew head for water.
Aug 14, 2011 | Saeco Magic Comfort Plus Espresso Machine
Coffee pot spills when pouring
This is a back flow problem.
the pressure of the fluid being push by air.
the small lip on the pot can't handle the flow.
go with a small tilt and you should be fine.
May 17, 2010 | Black & Decker Brew N Go DCM18 Coffee...
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
Coffee spilling out the sides of the carafe
I had a Mr Coffee that did that. It was running across the brew pause arm and making a mess. I discovered that the position of the carafe had a lot to do with it. If I brewed with the handle pointing out towards me, very little leaked out. I finally tore the brew pause arm off of the bottom of the brew basket. I works great and hey, I can wait ten minutes for a cup of coffee! However, if yours is new and doing this, I would contact the company and see if they'll make it good.
Jan 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Why does the coffee maker make a loud noise right before it brews the coffee?
Usually this is the expansion of steam as the heating element quickly rises to the preset temperature. This process heats the water to the correct temperature and causes the water to flow upward from the water reservoir. Then out the brewing spout over the coffee grounds.
It will usually make strange noises at the end of this cycle too.
The water is used up and remaining steam is vented.
Sounds more like a burping and last minute gurgle really. :)
Hope this helps!
Nov 17, 2009 | Keurig B100 Coffee Maker
Espressione cafe roma problems with pump
The problem might be the tamping pressure or the grind?
Jun 28, 2009 | Espressione Cafe Roma Deluxe 1329
Coffee leaking onto to counter top
I've worked on that problem on a X9, I am not sure if the coffee/milk spout is the same but, I had to dismantle the spout and clean inserts, I also had to replace the o-rings on the spouts.
May 17, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Coffee leaks after it is brewed
The water reservoir on this mdoel is very close to the coffee reservoir - if excess water gets between the wall of the coffeemaker and the coffee reservoir, it will leak exactly as you described. Make sure no water spills out of the water reservoir when your pour it.
-Tha Mp3 doctor
Nov 23, 2008 | Cuisinart DCC-2000
Miele CVA4070 Coffee Maker Logo
634 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
