Question about GE Energy Star WCVH6260F Front Load Washer
No washing I turn on the machine it starts the drain pump it runs for 3 min. then it unlocks the door and goes into pause start mode
  • 3 Answers
Hi, mine was getting to this point. After cleaning the filter all went back to normal. If you have not tried it, remove the three phillips head screws on the front bottom panel. You will see a plastic piece on the right hand side. You can unscrew it with your hand (drain water into shallow cake pan). Once water stops coming out, remove filter all the way and clean the pens, pencils, change, lots of lint, etc... out and put it back in. All should work well after this. Thanks, Greg
Posted on Jan 03, 2008
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
GE Washer, Model GBVH5140HWW. Door seal failed and water in washing machine leaked into the base of the washing machine. Removed the front panel, replaced the door seal, dried up the water in the machine...
The seal is likely not installed correctly. What is happening is the latch for the lock is trying to hook and it is being blocked so it doesn't actually lock. After so many tries the machine goes into an abort mode where it washes out all the water and stands by for it to be fixed. If you put some pressure on the door (closing it) while it is trying to lock, it likely will lock and then run. It is basically an adjustment issue. It is also possible that something with the lock mechanism is broken or out of adjustment causing the leaking to begin with and that is actually the area that needs attention rather than replacing the door seal. Door seals rarely fail unless they are physically damaged somehow.
Jun 02, 2011 | GE WSXH208A Front Load Washer
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Have a new ge WCVH6800 front load washer. Power was interrupted during washing cycle. Machine now stays in drain mode, stops after 3 minutes, door unlocks and start/ pause button flashes. How do you...
Hello there and welcome to fixya
You may want to try unplugging the machine for a minimum of 2 hours to let the internal cpu to reset itself then plug it back in then press the mode button then try to lock the door and it should be ok after that ok please inform me how this goes there is more we can do for this ok
Best regards Michael
Feb 28, 2010 | General Electric WCVH6800J Front Load...
Model ghw9200lw we get a code of F H or H F
hello FH No water detected entering machine or Pressure switch trip not detected If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
To cancel a cycle and select a new cycle
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Turns off during cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Jan 30, 2008 | Washing Machines
GE Energy Star WCVH6260F Front Load Washer Logo
63 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
