Question about Refrigerators
The circuit breaker trips when I open the refrigirator even when the ref switch is off
  • ken095292 May 11, 2010
    Sounds like there is a short in the light or light switch.
    Ken
  • Mike Smith
    Mike Smith May 11, 2010
    Need brand and model number to be able to help you .
    President:
  • 632 Answers
There must be a short in the internal lighting circuit which have one functional component, the switch. It is usually a white push-button inside the refrigerator near the door. The door pushes the switch when it is closed turning the light off. When the door is opened, the button pops back out to turn on the light. In your case, when you open the door you are switching on the light but the circuit breaker trips off. It means the short circuit is in the light wiring and nothing else. Retrace the wiring and you'll surely find it there. Rewire and have a good day.
Posted on Sep 25, 2009
My miele electric cooktop will not stay on after I trip the circuit.
Without more info this is difficult to answer. I will say that all cooktop's have thermal overload switches built into them. They open the circuit until it all cools down and they then close the circuit and reset. You begin using it again and bang it opens again and no power. This means you have a short circuit or a bad overload switch. If you are tripping the circuit breaker, you likely have a short circuit, which is why it is tripping the breaker. I would not keep resetting it, if this is the case. The more you blow or open the breaker the weaker it becomes. They open to prevent an electrical fire, which you do not want.
Nov 03, 2017 | Miele Cooktops
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
Chainsaw trips circuit breaker
Does the circuit breaker trip before squeezing the switch? Check the power cord - there's a short
Does the chain move freely before squeezing the switch? If not, and the circuit breaker trips while squeezing the switch, your chain is too tight.
Bottom line - tell us when the breaker trips and what you were doing when it tripped.
Dec 07, 2012 | Craftsman 16" Electric Chainsaw Chain Saw...
15 amp cutler hammer branch feeder type AFCI triped off and will not turn back on. I have tried switching off for 10sec and then back on and still nothing. Also, the test button will not do anything. The...
if the breaker has tripped the test button won't do anything ,, for the breaker to trip something down stream of it is causing this to happen,, check all the switches and or receptacles in the circuit that are controlled by this breaker, 3 types of line problems cause tripping,, ground to line, Line to line, and line to neutral. in this ,, also consider that extension cords, faulty appliances , ( lamps, radios, anything plugged in with a feedback short ) will cause the breaker to trip. even a nail to hang a picture that pierced the wire can cause this, add to that , a AFCI breaker will trip much more easily than one thats not, or even a GFI breaker, , try this, if you have the knowledge to do electrical work in a panel, if not get someone who is, switch the tripping breaker with another one of the same value, ( in this case 15 amp) see if the one you put in place of the one thats giving you problems trips. If it doesn't, you have a weak or bad breaker, so just replace that one, if it does, your going to have to trace out that entire circuit to find the reason for the feed back into the panel
Oct 07, 2011 | Electrical Supplies
Need to reset circuit breaker
  • 1 Turn off the light switches and unplug appliances in the room that has lost power.
  • 2 Find your circuit breaker box and open the cover.
  • 3 Locate the tripped breaker. Circuit breakers are small, usually horizontal switches labeled by the areas of the house they serve (for example, "kitchen," "bathroom" and so on). The tripped circuit breaker will be in the "off" position or in a middle position between "on" and "off."
  • 4 Reset the breaker by moving it to the full "off" position and then back to "on." That may clear an overload and return power to the room. If the breaker re-trips, you may have too many lamps and appliances plugged into the circuit; a damaged cord or plug; a short circuit in a receptacle, switch or fixture; or faulty wiring.
  • 5 Identify and correct the malfunction before resetting the breaker.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 25, 2010 | Computers & Internet
    Opened breaker to change light switch.closed breaker numerous times before it engaged.
    When you relaced the light switch, did you use the "quick stab" holes on the back or the side screws? The arc fault breakers can trip if using the quick stab holes on the back because they may not make a tight contact. This could be represented if the circuit breaker trips when the light switch is turned from "off" to "on". Try connecting using the screws on the side of the device instead.
    Jan 18, 2010 | Siemens 20Amp 1-pole arc-fault circuit...
    Won't start
    Check the door switch by listening for an audible click just as the door opens or closes. If you do not hear an audible click then the door switch is bad. IIf you hear this audible click then go to your circuit breaker box and check to see if they have tripped. If the circuit breakers have tripped reset them ONCE and try the dryer. If the breaker trips again DO NOT reset it. You have an internal short in your dryer and it will require further service.
    Jan 06, 2010 | Whirlpool LER4634J Electric Dryer
    Circuit Breaker
    you have 2 circuits that feed the garage , not a problem , the one that you stated tripped often is the one we are concerned with . now do you remember which one that was , if so we need to start there . the first thing to determine is the load on the circuit large enough to to justify tripping of the breaker , breakers tripping is not always an indication of a problem it simply means it is doing its job sometimes . To determine the load turn on all the devices normally on in the garage and get or borrow a amp probe a wrap around is the easiest to use open the breaker panel that feeds the garage and wrap the amp probe around the wire leaving the panel that feeds the circuit to the garage that is the one that trips see if the load is close to the rating on the breaker , if it is then the breaker is doing its job and the only solution it to split the load . now if the load needs to be split then don't forget you said you had two circuits feeding the garage so you might be able to divide the load more evenly between the two you already have before you have to run additional circuits , tripping of breakers is not always a bab thing in most cases in my 40 years of being an electrician it is a case of them doing there job and the load needs to be more evenly divided if this does not help let me know and we will dig deeper
    Jan 26, 2009 | Square D Qob120 1pole 20amp 120v Circuit...
    Tripping of circuit breaker
    Check what other appliances are on your circuit. What goes off when the breaker is tripped. You may need to relocate the microwave to a different circuit. Try to stay away from the refrigerator or AC circuits.
    Nov 03, 2007 | GE JVM1440 Microwave Oven
    Refrigerators Logo
    188 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
