Question about Mtd 22" Yard Machine Push Mower
My riding mower will not start , changed spark plug gas it trys then nothing
  • newbla May 11, 2010
    HOW LONG SINCE IT HAS RUN
  • 205 Answers
SOURCE: yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Posted on Apr 24, 2009
panilling9
  • 284 Answers
SOURCE: yard machine riding mower will not start
check all of your known safety switches!
Clutch has to be pushed in
seat switch (sit on mower)
blade disengage switch
Finally check your starter soleniod between the battery and the starter and look for fuses and check them out in the process
Posted on May 25, 2009
  • 7 Answers
SOURCE: My yard machine Riding mower will not Start
might want to check your safety switch
Posted on Jun 25, 2009
  • 1129 Answers
SOURCE: Spark plugs are being replaces every 3 or 4 mowing
the carb is located under the aircleaner it sounds like the mower is being fan at full throttle this on some mowers applies the choke try ajusting the throttle to full then slightly back to open choke.
Posted on Jul 14, 2009
  • 15 Answers
SOURCE: the mower starts easily but loses power and stalls out
You may need to adjust the fuel mixture screw on the carb to allow more fuel under load. And check to see if air cleaner is clean.
Posted on Apr 22, 2010
My John Deere D105 riding mower recently went under 2 feet of water during recent flood.change oil,gas & spark plug.engine turns over but won't start
May still have water in engine, try removing spark plugs and turning enine over a few times, may also have water in fuel line. Hope this helps
Sep 16, 2016 | John Deere Garden
Mower will not start after changing the battery out and checking all connectioncs
U could try to use some starting fluid spray into carb and have someone crank it right away But first do you have fresh gas in the tractor if not I would drain and fill tank with fresh gas. Also I always change my spark plugs at the beginning of the season,
Apr 10, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Has spark, has gas, cranks over and trys to start but will not
hello david,Has spark, fuel trys to start,could be bad fuel as old,water in fuel or tank,gas container with debris,crankcase over full on oil and gas,bad coil,bad plugs,low compression,blown head gasket,valves adjustment if ohv, these are the things i would check if i had it here in the shop,hope this helps,
Feb 19, 2012 | Garden
On my Craftsman Riding Lawn Mower the engine stalls after say about 10 minutes - I leave it for say 5 or 10 mins and I can start it again. I changed the sparkplug and it's not bad gas as my other mower...
The problem is more than likely the coil. The coil is nothing more than a coil of copper wire. When the coil gets hot the wire expands causing the coil to open or lose connection. When it loses connection then the spark plug quits firing.
PLEASE RATE! Click on the 4 thumbs ups!
Thanks! Have a GREAT DAY!
Oct 19, 2010 | Garden
Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Aug 23, 2009 | Garden
Murray Riding Motor Running but not Starting
does it have spark & gas let me know at wadembly@aol.com thanks,wade
Jun 07, 2009 | Garden
Have 2 craftsman riding mowers 42"cut one 16,50 kohler engine/the other 17hp. both have the same symptoms won't start tried plugs primed cylinders with starter fluid also gas, seems like they have no spark...
Take spark plug out ,put sparkplug wire on plug and let it lay against block. Watch to see if plug fires. If not change coil. Hope this helps.
May 18, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
238 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
