In the spin cycle it sounds like a jet plane taking off. What could be the problem?
  • dwellis1515 Sep 25, 2009
    That's what I figured. Thanks.
  • 10,515 Answers
This is a Common one specially on Neptune Washers.The rear bearing very common issue on the your washer.Unfortunately the cost is around 600 to fix this you can not get just the bearing because its part of the rear tub assembly.If you want the part number post back.
As a guide, i would advise you to go for a new washer as there are so many available in the market with lower prices.
I would say that lowes and appliance world will have the best prices i don't know if you have these places near you but that's were i would start!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 24, 2009
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
The spin cycle sounds like a jet plane taking off. Any ideas as to what it could be?
Main bearing failure probably. Have a look underneath for an oil or rusty water stain around the cabinet... If it has, it may be an expensive repair and probably not worth fixing.
Dec 21, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
Jet Plane noise in spin cycle
The bearing in the outer tub assembly is going out and you will need to replace it. Here is the part if you want to order it but you might want to look into buying another machine.
Nov 20, 2012 | Washing Machines
Sounds like the inside is a jet plane while in spin cycle very lose inside like something is loose ore broken like a belt
If the washer is vibrating a lot, then you could have a bad drum bearing. There are also counter weights and shock absorbers that could be bad. The best thing to do is take off the back panel and look inside. many times the problem can be clearly seen. Usually a loud noise like a jet plane on spin cycle means a bad bearing. This can be costly unless you can do the work yourself. The parts are readily available.
May 26, 2010 | LG WM-1832C Front Load Washer
Noisy during spin cycle, sounds like a jet plane at full spin.
the drum bearings have gone, expensive repair, this is caused by over loading the machine
Feb 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Spin cycle is loud
If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
Jan 18, 2010 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
