Question about HP Photosmart D7260 Printer
Installed new cartridge as indicated, and tried to print. GOt error message "Ink System Failure" error Oxc18a0101 Turned power off and on again, but same message.
  • k6be Sep 25, 2009
    Only one I found was different printer. Don't have those keys on the D7260 printer, so can't do the process. Unless I am misunderstanding the instructions.
  • HP Master
  • 1,684 Answers
Check out our web site at: www.ccl-la.com Click on the Printer service link and then HP. We have a step by step repair guide to get you going again. The problem is caused by air in the ink feed tubes and the guide shows you have to do a purge on the ink feed lines. You should be back printing in less than 10 minutes.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 25, 2009
Printing error message OxC18a050a unable to print
Hi
This is the error message which refers to ink system failure, printer shows this message when the ink system of the printer would not allow you to printer
Please follow the the steps given below
Make sure that the printer's power cord is connected to the walljack (Avoid if there is any surge protector or extension cord) Take out all the ink cartridges Take a clean cloth, dampen it in distilled water and with that cloth clean copper contacts of the cartridges firmly Let them dry for 2 minutes Unplug all the cables from the back of the printer while printer is turned on (After closing all the doors that are open and also keep the cartridges out) After 2 minutes, plug in the power cable Put the ink cartridges in one by one, then close all the doors again Printer would start going through some maintence and then would start aligning the ink cartridges All the best!! Regards
Oct 27, 2010 | HP Photosmart 8250 InkJet Printer
Changed all the ink - all new - still makes a rachet sound and shows Error Oxc18a0106 - will not print - what do we do now to have it print
Issue The product displays an '0x ... ' error message. The exact text of these error message varies by product, but it is usually preceded by the word 'Error .' If your error message includes the words 'ink system failure ,' and you use cartridges 564, 364, 178, 862, or 920, please refer to 'Ink System Failure' Message Displays on the Control Panel Common '0x...' error codes
  • 0xc18a0201
  • 0xc18a0206
  • 0xc18a0306
  • 0xc18a030a
  • 0xd0620130
  • 0x887dd03a
  • 0xd05d010d
  • 0xf0af8004
  • 0xc19ac3ff
  • 0xc18a050a
These error codes indicate that the product has an internal error condition. Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example)
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer wont print
this is a complicated error message so if the printer is in warranty immidiately contact hp or even if the printer is in warranty call hp you will get the support if you bought geniun ink cartridges how ever you can once try the following step Ink system failure is generally followed by an 0xc0...... error code and the trouble shooting is different for different error code so please follow this simple trouble shooting and even if the printer is not working then please specify the exact error code
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
is still you face the same problem please rerply us with the exact error code
Aug 28, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink sys failure error message
Try the following steps and check if it resolves the above error.
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
Wish
Aug 01, 2009 | HP Photosmart D7160 InkJet Printer
Printing error oxc18a0101
Try resetting the printer:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on.
Jul 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
PRINTER NOT ABLE TO PRINT
These error codes indicate that the product has an internal condition. Solution one: Reset the product Use the instructions below to resolve the issue by restarting the product.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Oct 23, 2008 | HP Photosmart C8180 All-in-One InkJet...
Oxc18a0101 error message - C6180 All-In-One
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plugthe power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Oct 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
ERROR MESSAGE APPEAR AFTER PRINTER PREPARATION OCURING. THE ERROR MESSSAGE THAT APPEAR , INK SYSTEM FAILURE. INK SYSTEM HAS FAILED. UNABLE TO COPY, RCEIVE FAXES OR PRINT. REFER TO DOCUMENTATION. ERROR...
Ink System Failure is a Hardware Issue, which indicates that the Ink Delivery system failed to initialize.
I suggest you to perform the below the troubleshooting steps, if it doesnt fixes, then the printer need to be serviced or replaced.
1.Turn OFF the printer, unplug the power cable and the USB from the printer.Then Press and Hold the ON/OFF button for 1 minute and then reconnect the cables and try again.If it doesnt fixes, goto next step.
2.Remove the ink cartridges, Turn the printer OFF and Unplug all the cables from the back of the printer.Connect the Printer directly to the wall outlet.Turn it on and wait until u get a prompt to insert the ink cartridges.If it didnt work, go to step 3.
3.Remove the ink cartridges again and close the access door.Disconnect the power cable while the printer is ON.Now Press and Hold the OK and CANCEL button.While Holding the OK and CANCEL button insert the power cable and continue holding the button until u get a message "NVM Reset" or untill the printer goes OFF.Then release the buttons and press ON/OFF button.
4.If you still get the same error, then the printer needs to be serviced.
Thanks
Riz
Apr 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart D7260 Printer Logo
279 people viewed this question
Seeker5211
Seeker5211
