Question about Vehicle Parts & Accessories
Alarm keeps going off about every hr or so how do i disarm it my factory antitheft alarm on my 2002 ford explorer
  • 344 Answers
Dark green wtih purple drivers door harness, ground this wire
Posted on Sep 30, 2009
How to disconnect the factory alarm
not sure if your having problems with factory alarm but if it is malfunctioning it most likley will again so here it goes...... to reset alarm insert key in drivers door turn key left then turn key right this should disarm and reset the factory alarm. to disable the factory alarm for good in the drivers door wireing harness look for the factory alarm disarm wire it should be dark green/purple with a negative polarity when your sure you have this wire splice a wire of the same size into it and ground the other end to the frame make sure that you have a good solid ground here and thah where you spliced into the wire is a good connection. this should terminate the factory alarm function hope this helps you
Feb 09, 2015 | 2002 Ford Explorer
How to disarm factory alarm theft system on 1997 ford f150
Just pull the fuse or unplug the wires at the alarm itself. Some times there is more than one thing on a single fuse is why I say just unplug it at the alarm itself. It just plugs into the wiring harness.
Oct 16, 2014 | Ford F-150 Cars & Trucks
How do i disconnect the factory alarm on a 2002 mercury mountaneer
Hello. Alarms are a pain and can cause problems. The best thing to do is disconnect the fuse for the alarm in the fuse panel of the car, then the alarm will not work at all. Also becarefull that it does not cause problems to the car itself. Good Luck.
May 26, 2014 | 2002 Mercury Mountaineer
I have a 1999 Ford Explorer Sport, and my alarm keeps going off without even touching anything. I have the remote for lock, unlock, and alarm and have to keep using it in order to disarm the alarm when it...
you have a bad feed censorit tells it when its being burguld or the main brain for alarm look for a local alarm company they will fix or disarm permantly
Aug 01, 2010 | Ford Explorer Sport Cars & Trucks
Is there an alternate way to disarm my explorer?
Well I believe you are asking other ways to disable the alarm.
Your alarm should reset after 1-2 minutes.
If this is an aftermarkert alarm you will have a fuse that you can pull to disable the alarm either under the hood or under the dash. Some will have a toggle under the dash.
If this is a factory alarm look in the owners manual or check with your local dealer service department for which fuse to pull.
Usually all you have to do is to take the key and lock and unlock the door.
Hope this answer is to your needs.
May 20, 2010 | 1994 Ford Explorer Limited
I want to disable the security alarm on my 2002 Ford Explorer.
my panic alarm keeps going off on my 2003 ford explorer for no reason.
Mar 16, 2010 | 2002 Ford Explorer
Ford factory alarm arm output and disarm output
I don't show this truck as having a factory alarm, is there maybe an aftermarket alarm in it
Dec 28, 2009 | Code-Alarm Code Alarm Transponder
is it a factory alarm, what is the year make and model please
Jun 22, 2009 | Code-Alarm Code Alarm Transponder
Need to disarm antitheft alrm in my 99 fierbird
You might have a problem with the antitheft system, I don't know what you've done or tested so far. But usually with the alarm enabled there wont be any start at all. It does sound like there is a problem with the ignition switch, but that's only if it starts and stalls after you let the ignition key go. The anti-theft alarm, is this a VTD, factory system, a factory alarm system, or an aftermarket alarm?
Jan 29, 2009 | 1999 Pontiac Firebird
Vehicle Parts & Accessories Logo
302 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
