Question about Worx GT WG150 10 in. 18 Volt Cordless String Trimmer w/ 1 battery
Where can I get a replacement spool cap for the bottom of the worx 120 trimmer wg120.
5 Suggested Answers
SOURCE: Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
Posted on May 30, 2009
  • 279 Answers
SOURCE: is the battery for the worx 18v string trimmer
All you have to do is check the sizes of the batteries. If they are the same size, by that I mean shape and dimension, there is no reason you cant use them on different equipment. ...Lee
Posted on Sep 14, 2009
  • 1116 Answers
SOURCE: I have a Worx trimmer/edger and I have 2 problems
Well your battery problem is quite simple. Litium batteries have a life and as the cells deplete, they will not hold as much charge as they once did. The part number for your unit is Worx WA3512.1 and can be purchased for about $53.00. As far as the spool retainer clip is concerned, you will be looking for a hard to find part. Here is the good news, you can purchase a brand new WORX GT WG150.1, which is the model you currently have, for only $95.00 on Amazon. I hope this helps you and let me know if I can be of additional assistance.
Posted on Jun 20, 2011
rycgl
  • 1545 Answers
SOURCE: Where can I buy a manual for a Worx 120 weed/edger
You don't have to buy one, when you can download one. Here it is:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0901668.pdf
This is a rather larger PDF file (like 6.6MG) so be patient.
Posted on Sep 04, 2011
How do you remove the Worx trimmer spool assembly ?
get this!
http://www.manualslib.com/manual/770460/Worx-Wg255.html
Jul 03, 2016 | Garden
Pineapple leaf jammed under spool housing. How to remove housing to clean out?
Usually the cutting heads have a couple of plastic tabs you push in to release the spool from the head
Mar 06, 2016 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Worx electric grass trimmer / edger wg116 restring. Need this one not 117.
Demonstrated on a Worx String Trimmer - YouTube
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
Sep 18, 2015 | Worx Garden
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
I have a Worx trimmer/edger and I have 2 problems with it. The battery doesn't last long enough to trim/ edge my yard. Normally I have to charge the battery 3 times or more just to trim my property...
Jun 20, 2011 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
The line keeps unwinding! The Worx trimmer seems to unwind the line when ever it decides too! What is the problem?
The spool can be defective, but it may be just affected by trash in the spool where it mounts to the machine. Look at this tip. There is a place at the end of it that explains how to clean and lubricate the spool. If you cannot fix the problem with this tip, replacement is probably your best option. Try it first.
http://www.fixya.com/support/r2827867-winding_line_trimmers
Best regards, --W/D--
Jun 04, 2011 | Worx GT WG150-2 18 Volt 10 in. Cordless...
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
thanks...
Charlie
May 29, 2009 | Worx GT WG150 10 in. 18 Volt Cordless...
Worx GT WG150 10 in. 18 Volt Cordless String Trimmer w/ 1 battery Logo
606 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
