Question about Kenmore HE2 Plus Front Load Washer
I am getting a flashing F-20 error at rinse cycle. We just moved and this is the first load on a 18 month old unit. Also, How do you get the front panel off?
  • 8,197 Answers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F20” error code.
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please refer to my profile and use the “Ask Me” feature if you require additional assistance.
Good luck and please rate
Posted on Sep 24, 2009
Was washing a load of clothes and once it filled up with water i am getting a dr flashing message. The door will close but it will not lock so i cant finish washing my clothes
if it still has water in it.... most likely you either have a obstruction in the clean out located front bottom of unit behind panel or the drain pump itself has failed.... the code is drain... it gets to its first rinse cycle the wont drain therefore will throw codes on you.... good luck service 18 years a/c and heating unlimited texas
Dec 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool front loaded getting stuck in wash and rinse cycle
You can remove the top cover of the unit and put your hands towards the door lock and just hit fair enough to get release the lock mostly it will open if not means just break the lock and replace it since if you are technician it will be easier for you if not kindly call the technician and do the service
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Front Loader GHW9150 PW
Yes, I fixed it after 10 hours of attempting. I called Whirlpool who in turn told me to call a Tech out to the house. I talked with a Whirlpool Rep who was at our local Lowe's, she in turn called their Whirlpool Guru who told her, there is NO override or manual way to fix the lock up unit/problem other than calling a Technician.
Well, I beg to differ. I took the panel off a 2nd time, looked for a pull, which there wasn't one, so I keeped feeling around the lock from the inside of the washer. I looked for anything that would move, press together, pull down and walla, bingo, I found a piece of metal that I pulled on and it released the door!!!!!!! Yahoo, then while the door was opened, I plugged the unit into the AC, it recognized that the door was unclocked, then I turned it to spin and rinse after it started flashing the F 11 code. I knew from this site, that it meant my soap had leaked into the unit. After running the rinse cycle, I am so proud to report that the machine is back up and running!!!!!
I thought, how awful not to have an external manual release, what if a kid got locked in the unit. Yes, a kid. My brother and I use to tumble in the dryer...lol Kids do, do dumb things. So even if Whirlpool tells you it can't be done,without a technician YOU can do it!!!! I'm a 60 year old woman and proud of it....Thanx FixYa
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport stopped in mid cycle
Read the Manuel and see if they offer an over ride, first.
Since you already tried rebooting the machine, I won't suggest that!
If no go you will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
464 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
