Question about Garden
I JUST PURCHASED AN ARIENS MODEL 2554 AND CAN'T
I JUST PURCHASED AN ARIENS MODEL 2554 YARD TRACTOR AND CAN'T GET IT TO CRANK. I PUT GAS IN IT AND DID ALL THE THINGS THE OWNERS MANUAL SAID TO DO AND IT STILL WON'T RUN.
  • 1 more comment
  • Chuck
    Chuck May 11, 2010
    New or used? Does it make any kind of sound at all? Does it turn over and just not start?
  • newbla May 11, 2010
    WAS THE GAS FRESH, IS THE ENGINE TURNING OVER
  • Al Roman Jun 12, 2013
    check the wiring behind the ignition switch. it may be disconnected. that was my problem
    Problem Solver:
  • 16 Answers
If it does not turn over with the key check the battery check the 25 or 20 amp fuse
Posted on Oct 03, 2009
My ariens lawn tractor is stuck in gear how do I manually put the tractor in gear and in neutral ?
Depending on the model of the tractor would determine what style transmission you have. However, there should be a by-pass valve located on the rear of the tractor. It looks something like a small piece of wire. Pull this by-pass valve out and you can then push the tractor.
May 04, 2015 | Ariens Garden
Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
May 08, 2012 | Ariens Garden
My riding mower keeps shuting off after using it for a little while
try and run it with the gas cap loose maybe the vent is plugged
Apr 28, 2012 | Garden
I have a ariens yard tractor YT 150 H model number 936012 serial number 004697 . I have replaced the pto switch and the relay and every time I engage the blades the mower cuts off. Could you please tell...
I have the same model and had the same problem. Ended up being a bad bearing in one of the deck pulleys. You can find it by disconnecting the drive belt for the blades and turning the pulley by hand. One of them is going to be a lot tighter than the other. You should probably replace both while you have it torn apart...
Oct 22, 2010 | Garden
Won't start, but cranks, If gas is put in air filter it starts
check carb for gumming----you may have to dismantle the carb and clean all the parts with solvent.
May 06, 2010 | Ariens 34 In. Zoom Series Riding Mower
Cutting size question
* f your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
