Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Sound shuts off. TV model 61SWX12B
When you turn the tv on the sound works, then noise comes up and the sound shuts off. it's comes on and off with the noise. After like 1/2 an hour it stays normal, but the sound is very loud before it goes to normal and i can hear the tv good. when i do the sound test and after is good only the follwing speakers work: FL, C, FR. The following speakers don't work:
SR, SL, SW. I don't even know where the ones that don't work are located inside the TV. Any ideas how i could fix this?
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
If this set was made around 2000 it may be the audio module that is no longer available---They had all kinds of troubles---if your set has this board (looking from the back of the set with the cover removed--unplug set first) it will be mounted above the main boards on the left wall of the cabinet---it is about 5 x 6 inches in size.
Basically the problem with these was they crammed a lot of stuff that gets hot on the board and solder problems develop---
You find this board you really only have a few choices--You can have the board removed and sent to a company called PTS ELECTRONICS WHO will repair/rebuild the board for you--You can find them on the internet.
This board has several plugs and only 2 or 3 screws hold it and the metal frame for it to the inside of the set----Hitachi had detailed instructions for this repair on their technical site---I along with several other techs who looked at this decided considering the amount of time to try to fix it---it was cheaper just to send it out for rebuild---PTS should have a 800 number and can give you a quote for this service.
Let me know if you have ANY questions or need advice. Any good TV tech who actually looks at this set will be familiar with the problem---The first one I saw was a brand new one with no sound from right speakers, right outs etc.
REGARDS, SD TECH
Posted on Sep 25, 2009
I have no sound on my hitachi 61swx12b
Howdy;
Try these items first: re-set TV and any type of BOX you have hooked to the TV. 2) Ensure all cables are secure. 3) Make sure that there is not a speaker switch on back of TV. 4) go into customer menu (audio) and make that speakers are turned on. 5)
Symptom: AUDIO MUTE OR HUM.
Cause: Remove ALL jumpers on bottom of SRS pwb.Add 1000mf@16v across CSH1 add 1000mf@16 across CSH4 add gnd wire 24ga from PSU1 conn pin 18 to IT02 pin 97.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 61SWX12B 61" Rear Projection...
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
May 15, 2009 | Mitsubishi WD-57732 Projection Television
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
Tv troubleshooting
There is problem in the power Supply section.check the h-out Transistor if Damage then Change for the Same COde #
Nov 13, 2008 | Televison & Video
Magnavox 27m53404/17 Picture went out
Hello there, I'm having a major problem with my TV, I have called all of the local TV repair shops and they all are the same, they want money money money before they will even speak with me about the problem I'm having. This is the only TV in my entire household for a family of 4 and we desperately need the TV in working condition for our kids. I don't want to have to put out $500 for another set if I don't absolutely have to.
The Problem...
About 3-4 months ago the TV when turned on, the picture would slowly come into view and be very scrambled and before the picture would come into complete view the TV power would shut itself off, but the power light would remain on. You can hear the "Click" noise when it would shut itself off.
2-3 seconds after it 'shut itself off' then the TV would make the "Click" noise (The same noise it makes when you first turn it on), it would make the "Click" noise over and over and over again but nothing would happen. So i would turn it off and on again and change the channel rapidly until after 2-3 minutes it would come into view and work.
So we decided to leave the TV on 24 hours a day. Then today we awoke and it was off and making the "clicking" noise over and over and over again but with no picture or sound. Now it wont even turn on/off it just sits there and goes "Click, Click Click Click" and doesn't do anything.
I described the problem as best as I can. Here is the TV information and specifications...
Philips 27 Inch Tube TV
Model Number... 27PT54 3S37A
Serial Number... 78438404
105 Watts
60HZ
120V
Date Code March 2003
Now that I typed the model number there are threads everywhere people saying the same issue exactly as me, I will read them but please someone tell me is there anything I can do...
Can anyone explain exactly what is wrong with the Tv and why it's doing this?
Also, what should I expect to pay to repair it?
Any information or help would be appreciated very much.
Thanks in advance,
Anthony
Just got off the phone with certified Philips shop...they said they will repair it for $100-$130 with a $25 down payment just drop it off and he will call me when its done. Does this sound like its worth it or a rip off?
Sep 07, 2008 | Philips 27PT543S 27" TV
Sound problems
you have defective speakers! you can repair your speaker change the spider suspension wire! thats why your speaker is crackle sounds!
Oct 01, 2007 | Hitachi 61SWX12B 61" Rear Projection...
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
TV went out
it shut down when was viewing ah..ok there is a short and could be in the horizontal circuit or in the power supply regulator any way thats a job for a tech...good luck
Aug 10, 2006 | RCA P46922 TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
