Question about Honda Quincy 17 - Gallon Air Compressor with 8.0 Hp - G18H17PC5B
Compressor wont start back up
Starts up fine fills up 150psi. When time to start back up to fill u hear moan like if its locked up. lossened the belt and electric motor works fine compressor seems to lock up. let cool and works once more could the oil have anything to do with it i put 10w30 wieght?
    President:
  • 1,922 Answers
Your motor start capacitor is bad, look for it on side of motor and for signs of bulging,leaking heat stress condition
Posted on Sep 25, 2009
I have a kobalt 236005 air compressor. It will fill the tank to 150psi properly. When it is time for it to refill the tank it will either trip the breaker or overheat the motor. It will not fill the tank...
Apparently you have a start capacitor, which acts as a surge tank to allow motor to start up under a load. Its usually a black cylinder shaped object with two [2] prongs with a wire plugged onto each one [1]. It can be tested with proper equipment, but should be reasonable to buy.
Sep 22, 2011 | Garden
I have the same problem as the one that cannot start after filling the air tank. I changed the start capacitor and the problem is still the same. Anybody knows why ? Thanks
Hi guyh815...
Check and replace your pressure shut off switch, normally they will cause this problem, if that does not solve your problem then check the motor.
Please take time to rate me
Aug 30, 2011 | Porter Cable Cable 20 Gal 150PSI Oil Lube...
Second time compressor tries to fill tank blows braker
The compressor pobably has a faulty unloader valve which bleeds the pressure off that is left in the cylinder when the compressor turns off . The unloader valve allows the compressor to start the next on cycle with the cylinder empty. Trying to start the compressor with the cylinder under pressure causes too much current draw and trip the circuit breaker.
Jul 06, 2010 | Campbell Hausfeld 10 HP 120Gallon...
Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Feb 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
My 94 park ave. moans when the a/c compressor activates. a/c other wise works fine.
Doesit moan all the time it's on or just as it starts. If it continues to moan then an orfice tube may be partly clogged. If just as it starts and goes away it's just the freon getting moving in an old car. the compressor has lots of miles and the seals are leaking interanlly in the compressor you say it's still cooling but if this is the case it won't for long. Sometimes the air motors in the dash move to the AC mode and they make noise as they move but should stop makings noise soon after startup
Aug 28, 2009 | 1994 Buick Park Avenue
Air Suspension for 2004 Hummer H2
hummer h2 hydraulic keeps running depleting battery.
May 22, 2009 | 2004 Hummer H2
After some excellent advice most of my problems with my airmaster 15/50 3hp compressor have been solved, but I still have one problem,the tank fills up to 150psi and swithes off,when I use the air and it...
The piston in the motor has a larger "problem" bucking up against the 100 PSI of backpressure already in the tank. Thus, the larger amperage required to start the compressor motor when air is in the tank. Does the compressor motor have a starter capacitor? Perhaps the capacitor has failed...
Mar 26, 2009 | Air Tools & Compressors
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Honda Quincy 17 - Gallon  Air Compressor with 8.0 Hp - G18H17PC5B Logo
165 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
