Question about Toshiba CZ36T31 36" TV
Toshiba 36 inch TV that has a shrinking picture. The bottom 4 inches of the screen is black and the top has about 20 white lines across it. If I bang on the TV it fixes the problem "for a while". Someone said its a cold solder on the vertical circuits? Where can I find the vertical circuits (which board is it?) and how can I tell if it needs to be resoldered? Thanks Rod
    Brigadier General:
  • 4,090 Answers
Rod,
To ask those questions indicates a lack of knowledge in a very specialized area. This is not really a DIY. Soldering is a skill, especially in an object that has fine tracks. Spill excess solder on the tracks and you will short out the whole unit. Overheat a component with a soldering iron and it will kill it. There is also the Radiation risk at the rear of the TV as well as High tension. You need to know how to ground the unit when opening it to prevent electric shock of a lethal type.
I suggest you call a professional in to do this or take it to a local repair shop. This also involves unsoldering an IC Chip and replacing it. There are numerous money saving DIY's on here all thinking they can do it cheaper and just as well as a trained repair tech. Some actually get in and do the job, but 96% are back in a week or so with either the same problem or greater problems than before.
You have to know WHY those things occurred, they may have been set off by some other part failing somewhere up the line. and technicians know where to look and have the equipment to test the integrity of the whole system as well as generating a test pattern to align the convergence and color wheels. Take my advice for what your life and health may be worth, take it to a repair man and have it done properly
Posted on Sep 24, 2009
Toshiba CF32H40 32"TV shrinking picture with solid black on bottom. What causes this and can it be fixed?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Same white lines on top of screen
you still go the warrenty on it
Jun 04, 2009 | Toshiba 32D46 32" TV
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Picture only in middle of screen
Sounds like vertical problems on your circuit board. Unless you have some electronics experience you'd better take it in for repair.
The inside of a tube TV contains high voltages even when off and unplugged.
GL
Oct 04, 2008 | Toshiba 36A50 36" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Toshiba CZ36T31 36" TV Logo
242 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
