Question about Earthway 2050su Broadcast Spreader
Need setting for Top Choice Please, 87 lbs per acre I believe. TY
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
Nov 16, 2016 | Office Equipment & Supplies
I have 4 acres front and back is 650 feet wide so hhow ow many feet deep will make the 4 acres.
There are 640 acres in a section.
A section is one mile by one mile
A mile is 5,280 feet
A square mile contains 5.280 X 5,520 = 27,878400 sq ft.
divide by 640 = 43,560 square feet per acre
multiply by 4 acres = 174,240 sq ft
divide by width 650ft = 268.06 feet
Ta Da!
Feb 12, 2016 | Office Equipment & Supplies
How many square feet per acre?square feet per acre
One acre is about 43,560 square feet.
Jun 20, 2014 | Garden
I have,some10 acres that are not developedbuthave electricity and water. it is relocatedin tge Palmdale area. iIs it possibleto put 2 or 3 mobile homes on this property?
Call local government in Fla and ask about septic permits, and lot-size minimum, and other related regulations.
Find out about building permits, minimum elevation, hurricane strap-down regulations etc.
Then contact local plumbing contractors about cost of septic, and ty-downs etc.
If all trailers are put on one septic, then later it will be difficult to sell each unit separately.
Mar 23, 2013 | Water Heaters
I have a speedy green 2000 broadcast spreader and need to know what setting I need to use to spread 40 lbs per 2000 sq ft dolomite peletized lime? Thanks.
first 40lbs per 2k of lime will do nothing, rate to chemnge ph 1 point is 50lbs per 500k which would be all the way open slow walk. for your application you should be about half to 3/4 open normal walk
Feb 06, 2011 | Scotts Company Garden
What per cent of one acre is 8,398 sq. feet? Like I/2 acre or 1/3acre
divide 8,398 by 43,578.582996 and you get this really long decimal, so you can round up or keep it that way. I will round up. It is about 19.271% of an acre. (answer rounded to nearest thousandth)
Apr 15, 2009 | Office Equipment & Supplies
2000 W reg ford escort wheel nut torque settings
2.0L DOHC Engine 85-105 Ft Lbs EX 2.0L DOHC Engine 65-87 Ft Lbs
Please let me know if this information is helpful. Positive feedback is appreciated. Thank You!
Mar 28, 2009 | 1989 Ford Escort
Math Word Problem
First, you need to get the probability of the two events - not enough rain and enough rain.
The probability of not enough rain is 1 less the probability of enough rain.
Supposing that the probability of not enough rain is 0.70, then the probability of enough rain is 0.30.
Therefore to get the profit per acre, you multiply these probabilities with their profits per acre. Hence,
$4000 * 0.30 + $1600 * 0.70 = $2,320 is the average profit per acre.
The above method uses the mathematics principle of the weighted expected returns.
I hope this helps.
Oct 09, 2008 | The Learning Company Achieve! Math &...
Earthway 2050su Broadcast Spreader Logo
226 people viewed this question
Top Earthway Garden Experts
Dennis Key
Dennis Key
john h
Are you an Earthway Garden Expert? Answer questions, earn points and help others
