Question about Canon PIXMA iP4600 Color InkJet Photo Printer
How to print envelopes with Canon iP4600
How can I print a Word generated envelope with the iP4600? Nothing suggested in the manual works. I'm using Word 10.1.4 on Mac OS 10.5.8. Thanks
  • arckon752 Sep 25, 2009
    I have downloaded a newer driver and can now print the envelopes, thank you.
  • julie25sh May 11, 2010
    What in the manual have you tried?
5 Suggested Answers
  • 36 Answers
SOURCE: Envelope Printing
What are you printing from? Word?
Posted on Oct 25, 2007
SOURCE: Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Posted on Jul 10, 2009
efs_perpends
  • 1996 Answers
SOURCE: Printing #10 envelopes with 5100cn,
You can download the manual for your printer here. You merely need to go to the word processor or program you're printing from and load the addresses and send them to the printer. Try just one as a test to make sure your margins and spacing are set up correctly.
For Dell specs on print media guidelines for your machine, see here. For a blurb about en velope loading, see here. All options here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 10, 2009
  • 121 Answers
SOURCE: How do you print envelopes on the Canon Pixma iP460
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Posted on Oct 09, 2009
How do i use canon ir4080i to print on A4 envelope ?
place the envelope, face up, in the manual feed/bypass and select the proper envelope when prompted on the screen. select the bypass from the touch screen (paper select) or from the print driver
Feb 17, 2015 | Canon Office Equipment & Supplies
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing C4 Envelopes on a CANON 2620N
try to use this linkhttp://www.canon.com.sg/section/contactus/?enqtype=TechEnq&enq_detail=Copiers
Aug 09, 2009 | Canon imageRUNNER C3200 Copier
Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
How do you print envelopes on the Pixma 4600?
Download a user manual from Canon's website. It is free.
Jun 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
327 people viewed this question
old marine
old marine
