Question about Elite Sl 3000 Ul Sliding Gate Operator
Photo eye installation
Is an additional module now needed to hook up the safety photo eye? Bought the dual motor unit from distributor who is no help at all. I believe previously the photo eye could be wired directly.
I need a replacement photoelectric switch for my outdoor Renaissance lamp model HB9902-98
The unit has motion-sensor/ photo eye capability built in.
There are no replacement parts for this type of device. Or long-term warranty.
The solution that comes to mind immediately is to rewire unit to by-pass the sensor, then install astro dawn-dusk wall timer in place of light switch.
http://waterheatertimer.org/How-to-wire-timers.html
Or install round box extension on the wall box, and wire up separate photo-eye mounted in the box extension.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Oct 13, 2012 | Hardware & Accessories
How to wire a photo eye to a Ramset
Ok, so you only want the Ramset to receive power at night?
Or you want to reverse photo-eye operation and only have Ramset receive power in day?
Are you working with household single-phase, or commercial three phase?
If this is at your home, what voltage are you working with 120V or 240?
What size circuit breaker controls power to this unit. Is it a single breaker for 120Volt, or double breaker for 240Volt. Look for power line coming from circuit breaker box.
For household wiring (non 3-phase), the power line from breaker box will have 2 wires, plus a ground.
The additional wires you have are probably for reversing motor, but I can't see the wires.
Copy following link to get started. And then add a comment, or re-post with more details, for example if you have link to the product manual with wiring diagram.
Aug 12, 2012 | RAMSET Ram 100 Slide Gate Operator 1/2HP...
I installed a new fan motor condenser in my air unit outside and I bought a new capacitor but it looks different than my old one in that my old one has three points of connection and the new one just two....
Look at the microfarad rating on the old capacitor and the new capacitor. Many are dual capacitors in one housing. The lower rating on your old capacitor is for the outdoor fan motor and the higher is for your compressor. It sounds to me like you have been sold a single capacitor when your unit had a dual capacitor originally.
Aug 03, 2011 | Heating & Cooling
My W840 message : 9.12.00 Service Motor Error
The PC (photo conductor) cartridge motor does not rotate at the specified speed.
Check the PC cartridge for installation.
Is the PC cartridge installed securely?
Check the dual drive motor assembly for operation.
Open the rear motor cover and check it.
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Drum unit motor.
Does the motor rotate normally.
Check the dual drive motor assembly for installation.
Is the dual drive motor assembly installed securely?
Check the rotation of the rotor in the dual drive motor
assembly.
Can the rotor be rotated by hand without excessive load?
Check the dual drive motor assembly connection.
Is the dual drive motor assembly properly connected?
Jul 13, 2011 | Lexmark W840 Printer
Door will not operate unless you hold down button
I am presuming the following: is it that the door will not operate unless you hold down the button to "close the door"? And the button you are pressing is the hardwired wall button or control inside the garage correct? And if you try to close the garage door with the remote the overhead lights flash off and on or the motor make a clicking sound (about 5 clicks?)
The problem is either an obstruction of the safety sensors at the bottom of the door or, one or both sensor eyes are out of alignment. If you look closely at both safety sensor eyes on the part that faces into the garage, you should see a glowing LED. One side will be an Amber color and the other Green. If one is lit (amber) but the other is not (green), that is an indication that the beam is not being received by the receiving eye (amber).
If there is no obvious obstruction (check for spider webs, dust, try cleaning the clear lenses facing each other, etc,) Try re-aligning the sensors. When they are properly aligned the Green LED will be lit. Now, check the motor for operation.
If you have difficulty getting the transmitter eye (green LED) to light, try closing the door at the wall button, then, pull the red emergency release handle to disengage the door.
Now, try operating the motor unit with the door disconnected while using the hand held transmitter. If the motor unit operates to the close position while the door is closed but not when opened, then that sounds like there is sufficient light entering the garage to "Wash" the transmitter beam out so the receiving eye does not get it.
Contact Chamberlain/Liftmaster for Sensor eye blinder shields that can be easily installed by you. (they just snap on) If neither LED is lit, make sure that the wire to the sensor(s) has not been cut off at the sensor itself. If that checks out, check the connection at the logic board. Make sure that both wires are securely connected.
If after checking all of that, and you do not have either of the LEDs on, then disconnect the safety sensor wires from the motor unit's logic board. Then take a 2" piece of bell wire and jump it across the two terminals for the safety sensors. If the unit operates normally when using the hand held transmitter, then the problem is likely: a) Bad safety sensors b) Broken wire to one or both sensors
To check if the safety sensors are good:
Remove both sensors from their mounting brackets. measure about 8" to 12" of wire from the back of the sensors and cut. You should have about 8 - 12 inches of wire on each. Now, separate and strip the insulation from each and then match the white striped wires and twist them together, and do the same with the solid non-striped wires. Take the sensors up to the motor head and connect the spliced wires to their respective positions on the logic board. Now, Point the two sensors directly at each other (its okay if the clear lens part are touching each other) Check if both LEDS are now lit. 1) If YES; then the sensors are good, the wire to them is broken somewhere; [FIX] replace the wires for both sides. 2) If NO: then the safety sensors need to be replaced. [FIX] Replace the sensors, contact Chamberlain / Liftmaster for replacement parts. You will need your garage door opener's model # which can be found under the light bulb or light fixture on the opposite side of the logic board. Having the model # speeds up the parts search for you.
I hope this helps you out. [I have been factory trained on residential and commercial garage door openers by Chamberlain / Liftmaster and have been providing installation and tech support on them for over five years. Prior to that I used to install and repair these units, and I've done that for nearly seven years.]
May 18, 2011 | Chamberlain & Liftmaster Garage Doors
Where is the ignition module located on a 1990 ford thunderbird?
the ignition module is attached to the distributor body, see photo below.
Jan 29, 2010 | 1990 Ford Thunderbird
OK 1997 gmc sierra 5.7liter 4x4 replaced coil and
Doesnt this engine use a crank position sensor? mounted on timing chain cover.I would check that first
Oct 17, 2009 | 1997 GMC Sierra
Elite Sl 3000 Ul Sliding Gate Operator Logo
22 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
