Question about GE DVL223GB Gas Dryer
Gets warm not hot - GE DVL223GB Gas Dryer
  • 403 Answers
A couple of things could be causing this, first one of your elements are probably going bad. Try this first. Pull out the lent holder and clean area well. Remove air vent hose and clean/vacuum into vent housing and also exit leaving home. Make sure hosing is clean. When you put dryer back make sure that the hose is not kinked. After all this if it does not heat as it should you might want to check out craigslist for another one. You can get a good deal for around 50-70. Your wasting more electric trying to dry your clothes. Hope this helps. Let me know if I can help you with anything else.
JimmyC
Posted on Sep 25, 2009
Water is cold regardless of the setting
I would check the water tempeture knob with a multimeter, u did check the water outlet hoses to see u are getting hot and cold water from them? Also if ur water inlet valve is bad it may only allow cold water or only hot water?
Feb 26, 2015 | Washing Machines
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
HOT and COLD blending
my last two washing machines, totally different brands and types, did the exact same thing. It must be a new way of setting them up, I don't understand either. I can't get straight hot water. My new one does seem hotter than the old one I had which was very distinctly hot then cold then hot then cold even on hot hot water.
Nov 09, 2013 | Maytag Washing Machines
HOT and COLD not blending correctly
The explanation I have in my file is that powder detergent does not dissolve properly in cool and warm wash cycles unless there is some hot water flow. However, I agree with your assessment.
Nov 09, 2013 | Maytag Legacy Series Top Load Washer
Why heater only warm
Either your thermostat is broken and jammed open (this means the water in the heater matrix will take forever to get hot) or you have an air-lock in the heater matrix. To check the thermostat, the engine should get too hot to touch before the radiator gets even warm. If they all get warm together, your thermostat is faulty. To bleed the heater matrix, uncouple the higher of the two hoses from the bulkhead an top up the water resevoir until you get flow from the loosened heater hose.
Oct 10, 2012 | 1998 Dodge Durango
Maytag washer will not get warm
1) the temperature coming from your house determine how is the temperature. You can get hot, cold or mix of hot and cold available to your machine.If the water is too cold affect the machine,and if is too hot, the warm temperature colapse.
If you live Northern are, unless you adjust the cold and hot verywell affect the temperatur of your machine.WARM water is better in summer and Colder during the winter.
God bless you
Jun 21, 2012 | Maytag Washing Machines
2006 pontiac grand prix, heat only gets warm not hot
Have you checked the coolant level? If that checks out ok... With the engine fully warmed up touch the heater core hoses where they go into the fire wall (about the center of the firewall). They both should be pretty hot to the touch. You'll likely find one hot and one warm. If this is the case flushing the heater core will likely get your heat blowing out hot again.
Mar 07, 2010 | 2006 Pontiac Grand Prix
I DON'T GET WARM WATER, WHEN SET ON WARM, ONLY GET COLD
If the setting is only hot and cold, there will be no
warm water coming out. At warm setting if it is
present, it should give you warm water.
Sep 23, 2009 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE DVL223GB Gas Dryer Logo
99 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
