Question about GE A730 Digital Camera
There are lines across the image - GE A730 Digital Camera
Akai 13" TV/DVD Combo CTD-1390 White Lines going across the screen with enlarged images on screen.
Retrace lines. This fault is called so. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to CRT screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 28, 2014 | Akai Televison & Video
Has pink/green horizontal line across top l corner
Hi,if your tv is dlp or lcd you will need to replace the light engine that's in charge of creating the image and colors, and when bad you 'll get discoloration or lines across image.
Oct 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Squigly lines run across screen cannot take pictures.
If its Canon A75 camera then its problem of defective ccd imager and Canon will repair your camera free of cost.
Click Canon CCD Imager Advisory for details.
Apr 30, 2009 | Canon PowerShot A75 Digital Camera
Lines appear across the photo when you print it
Try running the head cleaner function a couple of times.
That should solve your problem.
Feb 24, 2009 | Epson Stylus 1400 InkJet Photo Printer
Lines across the images
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
White lines across captured image
This is a CCD issue - may be possible to be remedied at Pentax FOC - get onto the Technical Support Team.
Jul 05, 2007 | Pentax Optio M20 Digital Camera
White line across image
sounds like capacitor problems or a possible ccd problem or driver problem .Its time to send in the unit for an estiamate. Cont # is 1-800-NIKON-UX , 1-800-NIKON-US Good Luck
May 11, 2006 | Nikon Coolpix 5700 Digital Camera
GE A730 Digital Camera Logo
20 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
