Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
Hi i bought an older ac 225c lincoln welder the 220 plug is differant from all my 220 supplies in my home circuit. what type of plug is it and what kind of adaptor do i need. thank you brett also i put an ohm meter on the stick wire and the groung clamp and the needel showed there was ohms is this normal the welder was off. thank you
    Problem Solver:
  • 18 Answers
Easy fix friend look at the face of your plug (the faces that go togeather).
there should be wrighting there. most welder have eather 30A/250V ,40A/250V or 50A/250V plugs. if you have a pluge that is larger then what you need already just change the pluge and breaker to the right ones. but dont upsize them the wire wont handle the and it wouldn work right amyway. Trust me i do electrical contracting for my living. if you need a new pluge put in just post and add on kijiji and you should be able to get it for a low price. if you need any other info drop me a line.
bubby123@gmail.com
Posted on Oct 25, 2009
  • 308 Answers
Your best bet is to go down to you local hardware store and pick up a plug the same as you are currently using in your shop. Hope this helps
Posted on Oct 02, 2009
Lost power to my redcat 220 ac/dc welder
You say you lost power to the welder. Did you check the circuit breaker where the power comes from in the breaker panel?
It will be a 2 pole breaker. If you mean the welder quit, then you will have to unplug it from 220 volt and open it up where the wire goes into the welder and see if the fuses are blown, if they are replace with the same type of fuses and try to weld again. If they blow again then you have a bigger problem and you should have a welding person take a look at it.
Oct 13, 2014 | Welding Tools
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Make extension 220 volt cord for 220 volt welder
most 220v welders have a NEMA 10-50 plug or the NEMA 6-50 plug--the input /output ratings thru recepticle and thru plug are same-configuration of plug prongs are different( Grainger Catalogue shows simularities and differences) main difference is AC Horsepower Ratings are different, and that applies Only on equipment that uses 3 phase, not your welder.Use an Ohmmeter to touch unpowered wire connection under shroud at ground and plug prong, then red power connection to corresponding plug prong, and again to black connection and plug prong,mark them w/ felt pen w/ corresponding colors (Green, Black Red). Change out wire plug to fit into dryer or stove recepticle, or make an extention adapter plug witch fits stove recepticle and extends out thru floor to carport and goes to 10-50 recepticle-whereas ground green goes to W position (Center) Y is Black and goes to Y Black, X is Red and goes to X red and cap off the white neutral coming from plug -welders and hot water tanks do not return unused electrcity via the white neutral (return) wire--they use up what is available on demand in heating elements or in welders - the electromagnetic field.GET HELP DOING THIS, by someone who has knowledge, SKILLS and EXPERIECE. I have 1 welder fitted to go into dryer plug which has 14-30 recepticle, and i have 1 where i kill stove circuit at panel, unplug stove, plug in 14-50 plug which has a 10-50 recepticle on other end, plug in welder 10-50 -p, flip cicuit breaker switch to on-welder has full power range capacity. No oven in use while welder going--but probably wouldnt run it anyway if on different circuit.Any doubts whatsoever--anything not 100% clear--DO NOT DO THIS or any other Electrical Manipulations--have a licensed electrician stub in a secondary circuit breaker off your main if load is acceptible and have him wire in the recepticle which your plug will fit into---.
May 31, 2012 | Craftsman Welding Tools
How much does this welder cost?
Hi:
That welder in new conditions should cost about 350.00 dollars. Used probably just 120.00.
Oct 17, 2011 | Firepower Flux Core Wire Feed Welder 88...
I need to find parts for my welder lincoln the fan coolin is not working
Any welding supply house can either get you a fan, or direct you as to where to find one locally.
--W/D--
Feb 19, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
Main power switch is broken. I have to turn the welder on and off at the breaker. Where can I get a replacement. It is a 220 AC welder. Thanks
Any local Airgas shop should be able to get you one or take the switch to Grainger and see if they can get you a replacement.
Mar 29, 2010 | Lincoln Electric K1170 AC-225 Stick Welder
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
620 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
