Question about Sony Video Game Consoles & Games
Ive connected my ps2 to a flat screen LG but the picture is jsut black and white. i ntoice the component part had a exstra 2 connection for video output where the cable i use has onle 2 audio and 1 video hepl please
  • 227 Answers
You have to purchase a component cable with blue, green and red connectors. This is a pcb set up. Also you will have to use your audio connections (red & white0 that correspond with the video imput you are trying to use. What it is doing is only getting one video signal through your yellow connector therefore displaying no colors.
Posted on Sep 24, 2009
I was trying to connect my ps2 with Panasonic vieara tv but picther is in black and white and no sound
A black and white picture suggests you are trying to use a composite video input but the TV may be NTSC format while your game is PAL, or the other way round. Use a game with the correct format or use the separate RED, GREEN & BLUE inputs (may require a different type of lead).
Jun 01, 2016 | Panasonic Viera TH-42PX80U Plasma TV
When i connect my ps2 to my lcd tv the display is in black and white but when i connect my dvd player there is no problem at all
This smells of a connection issue. Are you using the same cables to hook up both the DVD and PS2? If you are using component cables (5 heads) make sure the colors are matched up. Mixing those cables up can lead to a B/W picture. With more information as to how you are connecting both the DVD and the PS2 I might be able to find a more definitive answer for you.
Hope that helps!
Jul 19, 2011 | Televison & Video
Hi, I try to connect my PS2 to LCD TV and its has no color. The TV is LG and I tried the with SCART and with those holes on the side of TV (yelow, red and white). The strange is that when I start the...
make sure to set input on the TV is set to s-video.
If left on AV2 the picture is black & white.
Set to AV2S the picture is in colour.
http://www.avforums.com/forums/ps2/692572-ps2-picture-black-white.html
here some troubleshooting steps to help find out what maybe wrong
1. try a different tv 2. if you have a friend with a ps2 try borrowing their cable to make sure its not the cable. 3. try your friends ps2 on your tv.
Jun 01, 2011 | Video Game Consoles & Games
Component Input 1 & 2 gives black & white picture
You will need to connect all the cables for component to get a colour image.
The component cable has 3 connectors all for video. If you have connected only one cable for video then you will not get colour information. Component needs all 3 to get colour and luminence information. You can use a regular composite cable but you have make sure you match up the colour codes on both sides i.e to TV and to the source. The other two Red and White a separate cable is for Audio.
Y-> Green
Cb-> Blue
Cr-> Red
Jan 17, 2011 | LG 46LD550 46 in. LCD TV
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
When I plug component in to component 1 or 2 on my LG flat screen 42", sound is perfect but the picture is black and white and grainy-like a bad connection. This is consistent with both sets of...
This is a common problem for the 5-8 years old LG LCD TV, the problem is a defective main board, due to the new part dried out sources, the only way to do is to re-flow the soldering on the main board yourself by using your kitchen oven, this is the procedure:
Re-Flow Soldering Procedure for LG Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Apr 21, 2017 | LG 42 in. Flat Panel LCD HDTV
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Black and white picture
Since you're playing in a PAL region, it sounds to me like you're using the wrong connection for your system. You don't need to buy an SCART adapter for your cable, but if you pick up an RGB cable for your PS2 instead of composite, you should be fine. This is assuming you don't have a composite connection somewhere on your TV. Component (Y/Pb/Cr) would also be a good option. I can recommend a store here in the US, but I don't know if they ship internationally. The linked item is an S-Video cable, which will work well if you have an S-Video connection available. You can look for the other options on the site. Good luck!
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10830&cs_id=1083003&p_id=4008&seq=1&format=2
Jan 03, 2009 | Sony PlayStation 2 (PS2) Console
How to connect my COmponents to my new LCD TV
Do you mean a Playstation 2? If so, buy a SCART to component converter (like a SCART plug but with yellow white and red inputs) Put it in one of the SCART sockets and plug in your PS2. Hope that helps...
Jan 27, 2008 | LG 42LC2D 42 in. LCD HDTV
Video Game Consoles & Games Logo
161 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
