Question about Sakar Spider-Man 3 Digital Camera
I can´t see anything when i play - Sakar Spider-Man 3 Digital Camera
Mp3 is frozen
my mp3 player is frozen and won't do anything it says please wait updating play list and still won't do anything
Sep 28, 2012 | Eclipse 180 Sl mp3 Player
Movies will not play on my player
If the cd´s play and the dvd´s don´t the only thing are the motor disc spindle looses velocity and can´t read the dvd
Sep 10, 2010 | KLH KD1220 DVD Player
It says directx has unrecoverable eror
Hello shrestha89
Without more information, it´s difficult to give you a definative solution, as there are a number of factors that can result in this error.
Firstly, I´m assuming that you´re playing this on the PC, not PS3, as the PS3 doesn´t use DirectX. I´m also assuming that your PC meets the minimum specifications to play this game.
The first things you should try is un-installing/re-installing DirectX. You can download it directly from here: http://www.microsoft.com/games/en-US/aboutGFW/pages/directx.aspx
If that doesn´t solve the problem, update your graphic drivers.
If that doesn´t solve the problem, there are other solutions, but it would be much easier to help you if you could provide more information, such as when does the error occur, and the specifications of your PC.
Good luck
ajblaj
Aug 26, 2010 | Activision Call of Duty 4 Modern Warfare...
Why does my dvd player have two pictures with PSCAN displayed across the screen?
The progressive scan it´s for high definition Tv´s and if you´ve got standard tv need to disable that function
Jul 16, 2010 | Memorex MVD2022 DVD Player
Can´t play a vcd avseq01.dat in my dvd
You can use Media Player Classic or vlc media player to play VCD's
Get Media Player Classic here >>>>>>>>
http://mpc-hc.sourceforge.net/
Get vlc media player here >>>>>>>>>>>
http://www.videolan.org/vlc/
If i were you i'd download and install both the Media Players. You can play HD movies with Media player classic and just about anything with vlc media player.
Regards.
Jul 01, 2010 | Toshiba Satellite A135-S2276 Notebook
I have a Zennith portable CD-R/RW cd's play just
The problem it´s the motor disc spindle loses velocity and that´s why they can´t read the dvd
May 18, 2010 | Zenith DVP615 Portable DVD Player
Portable DVD won't play DVD but will play disk cleaner....
Change the motor disc spindle they loose velocity that´s why don´t play dvd´s
Nov 04, 2009 | Philips PET702 Portable DVD Player
My speakers wont´t work! i plug them in and I can´t hear anything! it´s not usb !
Be sure you have the plugs in the correct holes.
Feel free to move them around. The bezels on the sound ports are often color coded and will match the plugs you have. SOMETIMES they are not and you must guess.
Also make sure your sound settings have not been accidentally set to MUTE. Turn the volume up and play some music files or anything with sound.
If these speakers use power from the household plug.
Be sure the power knob is turned on! Usually the volume button.
If no external power is supplied these usually must be turned up full blast just to hear them. Some on board sound systems do not have the power to push the these speakers very high.
If all else fails
Update and make sure the correct sound drivers are loaded for your system.
If you have another set of speakers. Try them!
Cheap doesn't matter here.
Your only trying to determine the output works.
If it works then the other speakers may be defective.
Hope this helps!
Oct 04, 2009 | Compaq Audio Players & Recorders
I can´t play Windows Movie Films on my X-Box 360?!?! Can I Download a codec for this???I have some clips in Windows Media type on a CD. but my X-Box Can´t play that!!! Why???
Most likely there is not a codec available. If your Xbox is connected to the internet it will download the codecs if it can when you try to play the file. If not you can do what I did and download TVersity at www.tversity.com. This will stream movies from your computer to your laptop if they are on the same network, I use it to watch movies I have on my computer on my tv via my xbox. Anything your computer can play your xbox can play.
Jun 15, 2009 | Microsoft Xbox 360 Console
Sakar Spider-Man 3 Digital Camera Logo
12 people viewed this question
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Are you a Sakar Camera Expert? Answer questions, earn points and help others
