Question about Cameras
Hv 10 canon camcorder--can PLAY but camera does not work to record. red blinking light
SOURCE: Help with my Panasonic nv-ds1 camcorder ? ? ?
I had the same problem with my camcorder. I removed the battery for about 3 days and when i turned it back on it worked. is there a battery in camera to keep the time and date? maybe it is in safe mode and by removing power for long enough it will reset itself. paul sa
Posted on Jan 09, 2007
sonysonyman
  • 68 Answers
SOURCE: Canon ZR300 record button no longer works
hi sir just two things to do first 1- restore to factory setings from the menu and check if it is solved 2- if not just try to see does the knub is in its reguler state if yes so you need to replace it
Posted on May 08, 2007
  • 169 Answers
SOURCE: digital camcorder problem
there a short line to the carbon wire of the function switch.....unfold the wire to loose the fold....and clean the contact of the wire using a pencil eraser slowly
Posted on Aug 11, 2007
SOURCE: canon camocorder thick gray lines on ever recording
Supreemwun,
Canon support was of no help. They ****! To fix the problem this is what I figured out.
  1. Before you start filming what you want record or just advance the tape 10 secs or so.
  2. Record/ video whatever you planned.
  3. Now when the thick grey lines come up on play back don't freak out.
  4. Simply rewind the tape to the beginning and record briefly in the blank portion at the beginning (careful not to tape too long as to tape over your intended recording).
  5. Rewind and play the thick grey lines should now be gone.
How did I figure this out just a fluke. No cleaning, no spray pretty simple. At first did not understand it but it works EVERYTIME for me. I'll deal with it until I get around to buying a new HD video camera and it won't be a Canon. Hope this helps.
Posted on Jul 19, 2009
SOURCE: Downloading videos from camcorder canon DC230
same
Posted on Jul 31, 2009
I have a Samsung camcorder and when I play mini dv tape recordings from Canon camera I recorded on , the sound is distorted
If the tape plays correctly in the Canon camcorder, here are a couple of possible reasons for the issues you are having:
1. the Samsung camcorder has a cleaning issue - try running a dry head cleaning tape for about 5 to 10 seconds and see if that helps.
2. The alignment is off between the two different camcorders. Nothing you personally can do about that, but a repair center would be able to correctly align the tape path on both camcorders.
Do the tapes that you record on the Samsung have issues when you play them back on the Samsung? If so, you have a problem with that camcorder (may be cleaning, but could be a mechanism problem) Hope this has helped you. www.austintelstarservices.com
Aug 30, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
Have an IX1s Canon camcorder. Flashing red screen icon.
it means a particular battery is low or out of the camera, which hold the date and time memory of your videos. don't worry it doesn't affect your any recording or playback of videos. I have one and is blinking from past one month. no issues at all.
Dec 06, 2009 | Canon XL1S Mini DV Digital Camcorder
No video records w/ no LCD in camera mode, yet works in PLAY mode
You may have a mechanicle problem. what you should do is call canon.
Mar 15, 2009 | Canon VIXIA HV30 DV Camcorder
Red light blinking
i was filming, and i tripped and my gl2 hit the ground. it hit the battery kind of hard and now it wont work properly. now when i turn it on, the power light blinks red or green, depending on playback and recording mode. i want to know how i can fix this.
Dec 18, 2008 | Canon GL2 Mini DV Digital Camcorder
New Card
I don't know if this is related to the recording problem, but I believe the red blinking icon may be telling you to replace the backup battery. It's a button-type battery and is located under a small panel located in the area where the LCD folds into, just below and to the left of the buttons there. The battery is a CR1616 battery. Try replacing it and see if it resolves the recording issue.
Oct 30, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Recording stopped working
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
Apr 26, 2008 | Canon ZR200 Mini DV Digital Camcorder
Camcorder is not recording
the capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera....
Dec 13, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Canon ZR100 Mini DV Digital Camcorder Problem
I have a Canon4.gif ZR 10 And it does say remove cassette often and recently it eat the tape and destroyed our recordings.
Does this have something to do was the round small battery1.gif in the front part of the camcorder?
Is this a consumer complaint I feel uncomfortable because we have alot of Cassettes recorded and we are afraid to play them because it might chew them up.
There is a mini cassette player2.gif that can play the cassetes ????
Need Help!!!! What am I going to do ??? PNicioli@sbcglobal.net
Sep 24, 2007 | Canon ZR100 Mini DV Digital Camcorder
Cameras Logo
32 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
