Question about Garden
Added oil and now the mower will not start - Garden
  • 62 Answers
HOW MUCH OIL DID YOU ADD
Posted on Sep 24, 2009
How do you add pump oil and transaxle oil to transmission on craftsman mower 917.289140?
These are sealed transaxles and normally don't need oil added. There is a vent cap where oil can be added but this is normally done when the transaxles are being repair while removed from the mower.
Feb 04, 2015 | Craftsman Garden
Toro 22" recycler lawn mower, Briggs & Stratton engine. Engine low on oil, would not start after a few pulls. 20 oz oil added, mower started after a few pulls. Finishing the lawn when a white puff of...
Hi michael, You have most certainly put in too much oil. Try draining a bit off and then clean the spark plug with some paper towel. Leave the mower level for a few hours and then try it again.
Sep 22, 2013 | Toro Garden
Oil leak toro recycler 6.5hp lawn mower
Sounds like the bushing is bad where the crank shaft comes out.
May 19, 2013 | Toro Garden
I have a brand new TB250 21" self propelled mower with the Honda engine. I put it together, added oil, added gas, and when I go to start it it does not start. The issue is that I cant seem to get the...
Hi jb--
Since you have already added oil and gas, and this is a new mower, see if you can locate the 'dead man' switch on the mower. There should be a handle on the mower that must be held down when you try to start the mower. It will follow the shape of the larger handles, just about a third of the size: you can see it in the picture you used for this post. Attached to it is usually a cable that actuates a braking mechanism that will stop the mower's flywheel from turning. This handle will swing down against the handlebars of your mower before and then during normal operation. Try holding this safety down and try to pull again.
--Hope this helps.
Oct 08, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My lawn mower starts up but seems like it has no power to rotate the blade. Added oil, replaced air filter and the spark plug but still has no output power.
Is the choke stuck on? That could do it. Does it rev high enough ? May need adjusting. You say you added oil was it low enough you have almost seized the engine. Just a thought
Sep 21, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
White smoke and some oil coming out by exhaust
check your oil level in mower. probably too much.
Jul 04, 2010 | Toro Lawn Mower With Toro Power Tools
I have had my Poulan Lawn Mower for 4 years. The model number is 961320020. As I was mowing the lawn today, I thought that it might be running a bit sluggish and it dawned on me that I had not ever added...
Four years without adding or changing the oil?!
I think that was the problem right there.
Mowers need oil changes to protect the cylinder walls and valve guides every 25 hours of operation. Thats usually about one season if your yard is under an 1/3 of an acre.
Your mower ran on almost no oil for the last two years. The normal lawn mower only holds 20 ounces of oil. You topped off with 16 ounces! The four ounces still in the motor were probably so full of dirt and metal particles that it was grease! Which is no help to an engine that gets its lubrication by splash oiling.
Your mower should be oiled with 30 weight non detergent oil. Multi Vis oils are for engines with tighter machined tolerances. Your oil choice is going to go right past the piston rings and valve guides creating gobs of smoke! Go get some 30W ND oil at your parts store and put it in....but run the mower first so you can clean out all the gunk in the oil sump. Run it long enough for the oil to flow easily.
Once you put in the right oil you can run it and try to clear out the remaining multi vis oil.
If it keeps smoking...I would say you have permanent damage to the cylinder wall or valve guides.
Good luck and be careful!
Jun 24, 2010 | Poulan Pro " Pro" Self Propelled Mower
Cannot pull rope out to start mower
Bad news , Mower has sit up too long and the piston / crankshaft has become rusty and froze in place. (fix) buy some liquid wrench it comes in a can at your local hardware store...Tilt the mower onto its front wheels and remove the spark plug. Fill the Cylindar with the oil and leave it for a couple days. after a few days lean the mower back and attempt to pour out the left over oil. Then (Check Your Oil level) preferable replace old oil and pull choke..and start mower...if the engine is still frozen (Buy a New mower) 125bucks Sears.
Mar 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
