Question about Yamaha Audio Players & Recorders
Yamaha rx-v795a volume stopped working with remote
When using remote control to adjust the volume, the receiver displays the action (volume up or down), but the volume and knob actually do not move.
SOURCE: overheating?
I know this post is pretty old, but I just came across it. I have a GTP-750 that I have fixed. They do run extremely hot which causes the rectifiers in the power supply to fail. I have the rectifier part numbers to fix it as well as cooling method. I have been running mine now for about a year after fixing it sometimes at high levels for extended amounts of time and the case is now barely warm. If you need advice or pictures of my setup send me an e-mail
Posted on Apr 26, 2007
SOURCE: Yamaha RX-V800 Remote Control
Change the batteries
Posted on Nov 13, 2007
SOURCE: Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Posted on Dec 29, 2007
drumbanger
  • 1199 Answers
SOURCE: Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Posted on Jan 06, 2009
SOURCE: zune and yamaha RX-V663 Receiver
Buy the Zune A/V kit and hook it up to a non used rca port on the back. Look for the older ones for the 30 gb units, they are much cheaper than the new ones and it takes 10 seconds to modify them to use on the newer units. The A/V kit has 3 rca plugs, one for sound and 2 for video. If you pick a source that can play video and sound on your receiver, then the screen on the zune will display on your television. The A/V kit has a remote with it also so you can control the zune from the room. I have not tried it, but since the Zune remote is IR then if you have a good all in one remote, such as a harmony, you may be able to program the codes from the Zune remote into it and even be able to control your stereo and Zune from one remote. Hope this helps.
Posted on Feb 28, 2009
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
My yamaha rx-v795a works fine but the display is showing jibberish. What is causing this problem?
There is a Microprocessor(computer) that controls the display. This Micro can be bad, the display can be bad, the connections between the two, as well. For more information, please visit my website at audioserviceclinic.com. Thank you.
Sep 18, 2013 | Yamaha Rx V795a 5.1 Chan 425 Watt Home...
Yamaha rx v795a
change your launge settings
Sep 17, 2013 | Audio Players & Recorders
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
Need manufacturer's setup code for Yamaha AV Receiver RX-V373
Using 1056B03 universal remote from Time Warner. Several codes actually will turn the unit off and allow volume control. Or..I can turn on and volume control. Can't do both. I tried to use the receiver codes in the vcr mode, but the remote rejects receiver codes (i.e. only accepts vcr codes).
It looks like one or the other, not both.
Jun 16, 2012 | Yamaha Audio Players & Recorders
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
Volume Knob does not adjust volume, but remote does.
Check your owners manual for "factory reset" this will reset the main micro-processor. Otherwise the encoder (volume pot) needs cleaning, soldering or replacement. It could also be a cracked circuit board (if it has recently been hit)
Jan 28, 2009 | Yamaha RX-V1000 Receiver
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
Dec 23, 2007 | Yamaha RX-V795 Receiver
138 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
