Question about Peg Perego John Deere Gator HPX Ride on Toy
My John Deere Gator lost power even when I was pressing on foot feed and then died. It turns over when I try to start it but won't start. It showed where it had a little gas in it but went ahead and put some more but still doesnt start.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on Jun 12, 2012
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
SOURCE: kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
Posted on Mar 20, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 156 Answers
SOURCE: John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Posted on Jun 23, 2009
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
John Deere Gator
check your gas tank screw on cap......if there is a breather hose coming out of the cap....make sure the hose is not kinked thus causing a vapor lock in the tank
Jul 07, 2014 | John Deere ATVs
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have power from battery to foot pedal but no power from foot pedal out.
check the red and white wires at the foot pedal and make sure that they are showing 12 volts, also check the shifter and make sure that the connectors on the back are connected, you can also try jumpering wires from the battery directly to the motors just to make sure that the motors are good
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
Our john deere gator won't run
how do you know that the battery is charged? it could be that the charger isn't working. I would check the charger with a multimeter and verify that its putting out enough volts to charge the battery, it should be putting out between 13.8 and 14.6 volts
Apr 29, 2012 | Peg Perego John Deere Gator HPX
Gator lacks power when running in our front yard grass.
sounds to me like you have a bad motor, yes both wheels should turn
Dec 30, 2011 | Peg Perego John Deere Gator HPX Ride on...
I have a new battery and foot switch. Gator still has no power. Not even to the dump bed.
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Jun 08, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
171 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
