Question about Microsoft Xbox 360 Console
A solid red circle system isn't functioning please help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
This is known as a Red Ring of Death. It means you're Xbox has crashed mid-process. If you remove the power out of the back of the system, wait around 30 seconds-minute, then put it back in and restart the system, it should work again. If it still doesn't we would need more information, and it may be a Microsoft problem.
Posted on Sep 24, 2009
What does the sybol with the circle in the middle indicate on the dash board?
Well there are many images that could be shown in your dashboard
ANTI-LOCK BRAKES LIGHT
BRAKE PADS WORN LIGHT
So it could be either of the two. I would take your car to a mechanic and have it checked out.
Aug 22, 2016 | 2006 Audi A4 Avant
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
We cannot work out how to get the image of the picture we have just taken - please help!
There's usually a button on the back of the camera with a solid arrow right inside a circle, sometimes its painted green. Just press that, it should take you to the last picture you took.
If its not the one you want, most cameras have a circular button with north,south,east and west functions. Just press this button on the east or west quadrant to move backwards / forwards through your pictures.
Finally, google your camera make, model and the word user manual and download a copy. Should tell you all you need to know.
May 31, 2011 | Cameras
I have a jumbo remote, lost my manual. I would like to program it to operate a sanyo tv. I need instructions please.
First, make sure the device you want to connect with your remote is turned on, whether that's the television, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV, DVD, etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
If your device code isn't listed, try the Code Search function:
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
The codes to various devices are listed at:
www.remotecentral.com
Please note that there are often several codes for one particular device. It may take several programming attempts until you find the code that works with your device.
May 20, 2011 | Innovage Jumbo Remote Control
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
I own a 2005 Dodge neon SXT. Once in awhile a solid red circle pops up on my dashboard. What does this light mean?
The red circle means there is an intermittent problem with your vehicle security.If your car starts and runs fine it would be hard to diagnose until it wont start at all.
Dec 18, 2010 | 2005 Dodge Neon
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
Circles on my laundry
first lets figure out if its coming from, do you notice them before drying??? solid circle or a ring? streaks would be more a common complaint, but a complete circle?? does it come off in next cleaning ??
Feb 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Video display
Sorry I couldn't help you, I think this is your best bet. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&dlc=en&product=217312&lang=en
don't know what happened, the fixya chat closed itself... you can email me at gskellig@gmail.com if you need help with that other problem. =\
Oct 25, 2007 | Compaq FS7550 17" CRT Monitor
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
