Question about Canon CanoScan D1250U2F Flatbed Scanner
My computer sees the scanner but I can't get the Scangear toolbox to work, I can scan to a publisher file without problem. I am running XP on a 64bit computer. It says "Unable to select Twain source"
4 Suggested Answers
SOURCE: Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Posted on Sep 30, 2008
SOURCE: Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Posted on Oct 13, 2009
leecom72
  • 4806 Answers
SOURCE: Using XP Pro, with correct
You will need to install the twain driver for the scanner.
Click on the link below and download the driver. Once its downloaded execute the .exe file. you will then get a small box pop up with "Unzip" on the right hand side. Look at the path of the unzipped file on the left hand side and save it to your desktop. For example C:\users\yourname\desktop instead of C:\Users\yourname\AppData\Local\Temp. The file extracts quite fast so go to the desktop and run the SETUPSG.EXE file. When its installed you should be able to use the scanner.
Download Canon Scan gear here >>>>>>>
http://modrv.com/scanners/canon/402prog.html
Good luck and kind regards.
Posted on Dec 14, 2010
I need to get 64 bit driver for canoscan 4200F the file is no longer on the canon usa site and on the canon uk site it fails to download at the "accept licence" page. I also need the 64 bit canoscan...
Are you looking for the Window XP 64bit drivers? As those are not listed on Canon's support site but the Vista and Windows 7 64 bit drivers can be downloaded from the support site link below. The ScanGear software is also available on the USA site.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=10445
Robert from Blitware
Jun 16, 2010 | Canon CanoScan 4200F Flatbed Scanner
Can't copy or scan on canoscan lide 25
You need to install the software drivers You need BOTH programs installed on your PC, Toolbox & Scangear. Also use the driver remover first. Then unplug scanner, reboot, install Scangear first, and toolbox second, then reboot, when at desktop next time, plug in the Scanner. Hopefully it should be all good. Read the Help file. http://software.canon-europe.com/products/0010219.asp
Feb 17, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
Dec 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
Mar 30, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Launching Scan Software Launches my Browser
Canon Software doesn't work that well. Adobe Photoshop works well with my Canon N656U.
Also, You may need to run an error check on your computer.
Feb 13, 2009 | Canon CanoScan N656U Flatbed Scanner
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
CanoScan LiDE 50, error code:2,7,0
When you say the error occurs as soon as you press "Scan", is that the button on the scanner, or is it the Scan button inside of Toolbox or ScanGear?
If it is the one on the scanner, try accessing the driver through an application such as Toolbox. If you didn't download that when you got the driver, then go back to the Canon download page and download & install the CanoScan Toolbox. Once that's installed, lauch Toolbox from Start|All Programs|Canon|....look for Toolbox from here. Once you have Toolbox open, click the 'Save' option. Next, check the box that indicates to Use the scanner driver. Click the Scan button at the bottom. This should open ScanGear. Attempt to Preview scan.
May 11, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon CanoScan D1250U2F Flatbed Scanner Logo
67 people viewed this question
old marine
old marine
