Question about Sony Playstation 3 (PS3) Console
50" rear projection sony HDtv and ghosting when using my ps3
HI, I have a 50" Sony HD tv.  It goes up to 1080i.  Whenever im using my PS3 I get ghosting.  I go to the settings of the playstation, the game settings to be precise and change the upscaling from off to either normal or full screen.  When I do this it fixes the problem, however when you accecpt the changes ghosting comes back.
My tv shows that im using 1080i/60, when you try to change the upscaling from off to either normal or full screen it changes the hdtv setting to 1080i/50. This fixes the issue but as soon as you accept it automatically reverts back to 1080i/60 (this is when the ghosting comes back)
How can I fix this so that I dont get ghosting?
  • 3 more comments
  • Anonymous Dec 18, 2007
    i also have a sony 50" rear projection hdtv,this is the same problem we have encountered.
  • kouspo619 Nov 23, 2008
    i have also got the same problem with my sony 50 inch rear projection. i have had my ps3 on it at 1080i and i can see ghosting on it but cant see any solution to it. if a solution has been found could some one please tell me.
    thank you
  • CYW2008 Jan 28, 2009
    I have exactly the same problem with my Sony 50in Rear projector when viewing with the PS3. When I watch a Blu-ray or use the PS3 menu system (1080i 60Hz), I get it, but when watching a DVD on the PS3 which is upscaled to 1080I 50Hz it is an excellent picture. Same goes fo my Sky HD box that outputs 1080i 50Hz, that is an excellent.
    Will try hidden menu suggested below.
  • supermanfly1 Apr 08, 2009
    I tried these options in sequence and my tv is not turning itself on from standby. Can anyone advise me further?
  • Anonymous Mar 25, 2014
    where do you find the special access code for the cod ghosts pc game that allows you to let the game be played on the computer you downloaded the game on
  • 3 Answers
To bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "SHPos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Posted on Jan 08, 2009
  • 10vicky100 Feb 27, 2011
    Uve solved a problem that's been driving me insane many thanks
  • 182 Answers
When you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Posted on Jan 08, 2008
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Hook up ps3 and appletv to my tv - i have a Sony receiver w/HDMI slots that i am using for the PS3 - i have hooked up the Appletv to the HDMI input 2 on the back of the TV. The PS3 will not show video - i...
There are generally three HDMI slots at the back panel of an HD TV. Make sure you have connected the PS3 and the Apple TV in two separate slots. Sound will work because you must have hooked it up in Audio IN at the back or if you have connected the red and white audio cables in the front panel , the audio will work only on the camera setting on your TV
Feb 06, 2011 | Hitachi 50VS810 50" Rear Projection HDTV
PS3 display problem for multiple TVs
try to do a simple reset it will reset your video settings just turn it off then hold the power button then KEEP HOLDING until it beeps 2 times then it should come up note: it will not delete any of your data
Mar 04, 2009 | Mitsubishi WD62627 62" HDTV
Ps3 sony grand wega (4 yrs old)
Press the input button on the tv itself to select the proper input you desire.
Dec 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
PS3 not recognized by Mitsubishi WD=52525 tv through HDMI
FYI,
PS3 has output settings and would need to be adjusted if you are coming from the RCA input. Check out www.sony.com/ps3 trouble shooting under display problems. I believe the solution is to turn on the PS3 unit and keep holding the I/O button for more than 5 seconds. I had the same issue going the other way.
Good Luck.
Sep 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Will not display 1080p from a Sony ps3??
Connect your PS3 through the HDMI 2 port on the TV and as a PC under the tv settings. Then auto setup the tv on the PS3 and it will now see it as 1080P. It will give you some error message whenever the PS3 is first turned on but it will work. Hope this helps everyone.
Ryan
Jan 20, 2008 | Mitsubishi WD62627 62" HDTV
Hooking up my new PS3 to my five year old 55" Mitsubishi HDTV.
The Sony outputs 180P, not 1080i. There is a difference. I don't know what exactly, but Sony says 1080p is for superior.
Dec 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
HDMI Monster cables
I had the same issue. I think you have to reset your PS3. I don't remember how I fixed it but I did find the anwser in the PS3 user manual "Trouble Shooting".
Dec 27, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Playstation 3 (PS3) Console Logo
656 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
