Question about Goodman Heating & Cooling
Goodman CHTD18-60 thermostat needs reseting
I have a Goodman CHTD18-60 thermostat. We started using the heater for the first time today and several times we have had to reset the thermostat using the reset button. The display for current room temperature shows LL and the thermostat will not respond until we hit reset. Any ideas? Thanks
SOURCE: Rinnai rce-606tra II -- temperature is wrong
move thermister probe higher on back of unit
Posted on Mar 10, 2008
SOURCE: Not properly drying
If you remove the front cover hitting the reset switch is rather easy. However I did that the other day and only got 1 load done before it tripped again.
I just picked this dryer up used from a buddy the other day and am already having trouble. Also... It runs very loud. How loud is yours complared to the washer?
Posted on Jun 06, 2008
SOURCE: Heater won't start error code 11
I had the same problem and the heater started working after I cleaned both filters, the bigger one that can easily be taken off and the smaller one that needs to be screwed off.
Posted on Jul 15, 2008
  • 14 Answers
SOURCE: warming up problem
This has nothing to do with the element. This oven should only be serviced by a qualified technician. If you were one, you would already know the solution. You need to go into diagnostic mode to determine if it is the solid state relay or the cc thermocouple. After resetting the hi-limit more than once, it will also need to be replaced.
Posted on Jul 31, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMS90904CXA Wont ignite, light blinks 3 times
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
Posted on Oct 21, 2008
Code 1 on a goodman furnace. Changed filter, reset thermostat, hit the breaker for reset and still the temp is dropping and the unit is not kicking from the thermostat. Thermostat is only a year old.
You unit is under locked out mode due fail on start up. Get sand paper clean out the flame sensor, and jump the 2 wires that go to the pressure switch as soon as the inducer came on. Doing this the flame should stay on until it meet set temp at thermostat . If it does what said your pressure switch need replacement . Good luck and keep me up to date .
Feb 02, 2014 | Goodman Heating & Cooling
Goodman GS9 blowing air but not getting hot
Does furnace fire up ,if not you have a issue with your furnace and not thermostat
Feb 12, 2018 | Goodman GMS90703BXA Heater
Sytem lockout in the goodman heather
Turn the unit off, then back on this should reset the fault. If it does not
go into heating mode make sure thermostat is turned all the way up.
If nothing still doesnt happen then you need to make sure a breaker is not tripped.
If the furnace starts,then a hot surface ignitort should glow, if it doesnt
either it is cracked or the induced draft blower didnt come on. If it did glow and the burners lit and shut off, then the flame sensor is dirty and needs to be cleaned
Feb 04, 2010 | Goodman GMS90703BXA Heater
Furnace won't turn on....
jump out thermostat or try jumping out the pressure switch
Feb 23, 2009 | Goodman GMS90703BXA Heater
Furnance will not come on
No Blink? no call for heat. Check thermostat. Jump out thermostat. Check the fuse in the cabinet as well as in the breaker box. Do you have an emergency switch that may have been turned off? Make sure the door interlock switch is closed and working.
Jan 29, 2009 | Goodman GMS90703BXA Heater
Goodman GMP075-3 ignition problem
bad board,i have had several board failures on goodman
Dec 18, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman furnace
sounds like the fan switch in the furnace is coming on and off. This is common for Goodman. or could be the heat anticipator on the t-stat. While there are several reasons this happens these are the most common.
Guy
Oct 29, 2008 | Heating & Cooling
Goodman heater
Depending upon your installation the filter could be located in the bottom section of the furnace right or left of the blower, remotely located in its own housing in the return air plenum or it may be missing altogether. If you can find a spot to put one in, do it. You may just have to reset your thermostat. Some models have a pre-timed indicator that comes on after a number of hours reminding you to check your air filter. Post the model number of the thermostat and maybe we can help you reset the timer.
Nov 10, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
126 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
