Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printhead problwm#1 - HP OfficeJet 6110 All-In-One InkJet Printer
    Problem Solver:
  • 14 Answers
Hi ,
You can try this,
Take out the printheads .
>>do pwr drain.(take out the power chord and press and hold the power button for 20 sec.
>>chk the part no. on the printheads and exp date.
>>clean the copper contacts of the printhead and of the printer.
>>put the printheads back one by one.we call this hard reset.
>>if this doesnt work you can try to reset the printer.
we call it as NVM reset:: take out the power cord and press and hold the cancel + power.
>>this surely work.
>>any further issue with the hardware if the printer is in warranty give a call to the Hp printer department and they surely change the printer.
Posted on Oct 04, 2009
Testimonial: "i know you are great my friend "
NEED INSTRUCTIONS ON HOW TO CHANGE OUT A PRINTHEAD ON A OKIDATA 3410 PRINTER
Printhead
(1) Open the access over.
(2) Pull up and rotate the head clamp 1 to unclamp the printhead 2 as shown fig. 3.3.1.
(3) Disconnect the printhead 2 from PC connector 3.
(4) To install, follow the removal steps in the reverse order.
Notes on installation:
(1) Insert the printhead 2 into the PC connector 3 while pushing it against the carriage
frame 4.
(2) The head clamp 1 must surely be sandwiched between printhead 2 and carriage
frame 4 as shown Figure 3.3.2.
(3) Be sure to check the gap between platen and printhead (see 4).
(4) Be careful not to touch the print head while it is very hot.
(5) Make sure that there is not any dust or oil on the connector contact section A. If it
is found, wipe it off by alcohol. Good Luck ! I couldn't attach any pictures.
Dec 17, 2010 | OKI Microline 3410 Matrix Printer
Windows xp not install heng problwm more restart
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Nov 24, 2010 | Hitachi Deskstar® T7K250 160 GB SATA Hard...
When it prints black cant hardly see,if i print a color and black and white you cant see black print
Common error for Printhead that some colors on your printout are missing.
1. Clean printhead twice press menu button> select clean printhead> select basic/deep clean
2. Test Print Press photo and copy button at the same time for atleast 10 sec. or until it prints
3. Reseat the printhead Simple remove the inkcartridges and the printhead close the printer access door without the printhead. Open the printer access door put the printhead and the inkcartridges back. Then close the printer access door. DO TEST PRINT if still missing colors
4. Replace printhead Contact Kodak AiO support line at 1 800 421 6699
Nov 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My pictures are all printing with a purple look, such as water, clothes, sky, etc... There is no other color hue, besides purple in the picture.
Issue on kodak AiO printer not printing correctly you need to contact kodak support line at 1 800 421 6699 for printhead replacement.
Step that you can try
1. Clean Printhead twice press Copy button and Cancel button at the same time for atleast 10sec or until the printer move. Note cleaning printhead will consume your ink.
2. Reseat Printhead open the printer access door remove the ink cartridges and the printhead then close the printer access door wait until red light flash on the printer open the printer access door insert back the printhead then ink cartridges
3. Replace printhead contact kodak support
Nov 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer says there is a paper jam and there is no paper in there.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer
2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead
3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
Nov 17, 2009 | Kodak ESP 5 Printer
Printer error 07,010.43:722 on phaser 8560 xerox printer
Hi eduardo580:
This your problem.
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
1 1.
Reboot the printer.
2. Did this correct the problem? Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
prevents the printhead from moving to its
center position? You should be able to
manually push the printhead right to left.
Clean the printhead area. Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
it’s center position (so it can tilt forward)?
Go to step 5. Troubleshoot the X-axis drive.
5 1. Check the process gearbox for obstructions or damaged.
2. Ensure the gears are correctly aligned and homed.
3. Verify the process shaft and drive module shaft are at their home positions.
4. Did this correct the problem? Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
drive train (near left side of the printhead).
Clean the gears. Go to Step 7.
7 1. Use service diagnostics to run the Head Maintenance Wiper Clutch test.
2. Did the test fail?
Replace the wiper drive clutch. Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper Drive Test.
3. Did the test fail?
Replace the exit module assembly. Go to Step 9.
9 1. Use service diagnostics to run the Load Maintenance Clutch test.
Inspect the maintenance drive system,
replace any defective parts. Go to step 10.
10 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
2. Is the gear engaged properly?
Go to Step 11. Set the headtilt gear.
11 1. Use service diagnostics to run the Tilt Axis Drive test.
Replace the process gearbox.
Go to Step12.
12 1. Use service diagnostics to run the Process Motor test.
2. Did the test fail? Replace the process motor.
Hope this helps
Jul 25, 2009 | Xerox Phaser 8500/DN Printer
ITunes error codes: 4450 & 4900
udde you have to get lime wire then you can get your tone !!!!!!!!!!!!!!!1
Apr 14, 2009 | Gateway GT5220 PC Desktop
Need to know how to put in a print head
dear angie
Turn printer on
Raise scanner lid (grey KODAK lid)
Watch print cartridges automatically center and stop
Remove each cartridge (pinch the lower lip to upper)
Put index finger on printhead 1/2 inch above bullseye - on underside of upper bar - below the 1/2" slot in printhead
Find 1/2" "button" and push firmly; printhead snaps loose
Tip forward and lift printhead out
rlmontgom
Feb 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
XEROX 8550 7,010.43 error code
Hi guitargurl:
Your printhead is stuck in the tiltposition,or is not able to tilt forward to the print position, due to another problem with a motor
7,010.43:
7,011.44: This is a soft fault, and will not halt the printer.
7,012.45: The drum transfix home sensor is still in a not homed position, after the
return home motion has been completed.
7,014.47: The printhead is not locked in the head tilt restraint spring.
7,015.43: The head tilt restraint spring is out of place.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Reboot the printer.
the lock arms.
Clean the
printhead area.
Go to Step 4.
the X-axis
drive.
or damaged.
homed.
Clean the
gears.
Go to Step 7.
test.
Replace the
wiper drive
clutch.
Go to Step 8.
Drive
Test.
Replace the exit
module
assembly.
Go to Step 9.
Maintenance Clutch
test.
Inspect the
maintenance
drive system,
replace any
defective parts.
Jan 08, 2009 | Xerox Phaser 8860MFP Printer
IDS failure, call HP message comes up
Hope this helps you. This error is caused by either a correct or incorrect detection of air in the manifold. The steps below will clear the error condition, which should solve the problem if it is caused by an incorrect detection of air. If there really is air in the manifold, however, this procedure will not solve the problem and the printer will have to be serviced. Step 1 - Remove all printheads CAUTION: Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children. Figure 1: HP 14 printhead c00042423.jpg 1 - Handle 2 - Tower
  1. Make sure the unit is plugged in and the power is turned on.
  2. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  3. Wait two or three seconds, then unplug the power cord.
  4. Open the printhead latch. See the illustration below. Figure 2: Open the printhead latch c00042424.jpg
  5. Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below. Figure 3: Remove the printhead c00042425.jpg
Step 2 - Reset the internal error state NOTE: This step must be performed before the printheads are re-installed.
  1. Close the printhead chute.
  2. Close the access door.
  3. Plug the power cord back in.
  4. Turn on the power. The front panel should read No Printhead. Will damage Product. Insert [color name] [icon] printhead now . NOTE: The carriage may make a grinding noise when you turn the power on. This noise is normal.
  5. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  6. Wait two or three seconds, then unplug the power cord.
  7. Open the printhead latch.
Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry. Step 3 - Insert the printheads
  1. Place each printhead in its slot in the printhead carriage. The colored shape on the top of the printhead should match the colored shape on the proper slot on the printhead carriage.
  2. Press down firmly and evenly on both the front and back of the printhead, as shown in the illustration below. Proper seating is essential to making good electrical contact.
Figure 4: Seat the printhead c00042431.jpg Step 4 - Close and check the printer
  1. Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below. Figure 5: Loops catch hooks c00042432.jpg
  2. Snap the latch into place.
  3. Plug in the power cord.
  4. Close the print carriage access door.
  5. Turn on the power.
  6. If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press Enter to align. If the error persists contact HP. Printhead replacement will not resolve this problem - the printer will have to be serviced.
Jan 08, 2009 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
162 people viewed this question
Seeker5211
Seeker5211
