Question about Philips Magnavox Learning Universal Remote
A friend gave us a 52 in sony television, but she can't find the remote since it is still packet away from moving. I am looking for a code to try our Philips Univeral remote. The Mode # is KPR-53CX35.
  • 403 Answers
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
Thompson tv left in sleep mode and lost remote
Buy a universal remote and in the packet is a list of code numbers for all TVs so look for make and away you go or look around the boot sale often find them here
Mar 21, 2012 | Televison & Video
I have a 2002 sony 52" rear projection screen and the remote broke. I tried a couple of universal remotes but they dont work. Is there a remote that is compatable with it or do i need to purchase a new...
Try website 1-800-Remotes Factory original.Buy an exact remote.Best,because codes,sometimes codes in the manual wouldn't work u find that out.Must keep the dam manual safe all the times,like battery dead,or run low.Must re enter the dam codes again.
Apr 12, 2010 | Sony KP-51WS500 51" Rear Projection...
Flashes a code on screen different every time, all over the screen
tried to get channels would only give me on and the viedo shows blue screen other channels shows lock on them dont have a remote friend gave to me dont no code
Feb 11, 2010 | JVC AV-32F476 32 in. Television
Got tv from friend want come on
Its over heating I have the same problem! the quickest fix is
to find away to get cold air blowing to back of TV. also move away
from any heat.
good luck
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture looks stretched, people are squatty looking
You may only need to change the format for the picture. Check your owners manual for how to change the picture format, or aspect ratio. The tv may be in the zoom mode the way you describe it. There is likely an option in the menu to allow the unit to automatically set the format based opon the signal being received. Only some of the programming you see is actually HD. The Super Bowl was broadcast in HD and has a 16:9 aspect ratio (width to height). When this set is adjusted for a correct HD display I'm confident you will be impressed. So I believe this is a matter of a customer setup with the remote. If I had the unit in front of me I could offer more detail. I hope my general opinion helps.
Feb 02, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
RCA remote problem
Look and see if you are on TV output or on aux outputs.
Sep 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony 52" rear projection tc
5 blinks means problem in the AKB (video) and 4 blinks means problem with the verticle deflection. Try this to get the screen to display any recent faults then get back to me and let me know what it said. Press the following buttons on the remote.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
Jan 13, 2008 | Sony KP-41T65 41" Rear Projection...
Sony 52"
i have a sony kp-53v80 i have a double vision or red lines on the left side of the screen. a repair guy fix it once by using the remote and puting in a code that brought up a white grid and it showed the red was out of line and he moved it back in line and it only took a few seconds to fix ... how do i get to that grid using the remote
Dec 28, 2007 | Sony KP-53V80 53" Rear Projection...
Philips Magnavox Learning Universal Remote Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
