Question about Numark CDX Turntable
CDX motor problem
My turntable may have been bumped a lil to hard sad to say.... My problem iwith the motor is that it spin's outta control fast and when grab the plater it then take's off in reverse outta control FAST... So my question's are, dose the motor need to be replaced? Or is there anyway of repairing the mottor?? Or is it a competely diffrent part?? Thanks for any solution you may have to offer
DougieDGroove
  • dj koolaid Mar 10, 2008
    hey am from the bahamas and my play has almost the same problem it spins fine fa a while then it stops and start 2 scrach by its self back and foward what should i do please help
    Problem Solver:
  • 7 Answers
Sounds to me like the ac to dc rectifier/transformer is shot. AC has a positive and negative pulse. Your turnable motor takes DC current. Their is a device that modifies your ac to dc. if the motor takes off on the positive pulse it goes forward. When you disrupt this it starts to act on the negative pulse. it may not be motor but some electronics.
Hope that helps.
Posted on Dec 18, 2007
Turntable spinning to fast
Clearly an electrical fault. Could be something to do with the power supply or the speed control circuit, or even the motor itself.
For the manual visit the Gemini website.
Apr 21, 2013 | Gemini PT-1000 II Turntable
Hitachi Ht-354 direct drive. Why can't speed be adjusted?
Direct Drive turntable's have electronically controlled motors with complicated systems to keep them at the right speed.
My guess is that there could be a power supply issue that feeds one of the motors that is sending a much higher voltage to it. But that's just a guess. You might want to look around for the service manual for it to see how the motor is controlled.
May 01, 2012 | Audio Players & Recorders
I have a Sherwood PD - 913 R and the pitch seems to be spinning out of sync which makes the RPM"s not right for 33 or 45 speeds, any help on what could be the cause is appreciated. There is a pitch...
The turntable motor might be the problem, if the grease is old it becomes hard causing the turntable to run slow, by your description we can rule that out since you indicate it runs to fast. therefore it is the voltage that powers the motor with a regulator "keeps voltage constant" or the motor itself will be the problem. The pitch control allows a small change in speed when required.
Dec 30, 2010 | Audio Players & Recorders
My platter spins fast out of control
At a guess from the minimal informaton given, i would say the drive motor has gone. I would suggest taking it to your nearest dealer or service center for a full overhaul, appart from that, visit e-bay.
Oct 24, 2009 | Technics SL-1200MK2 Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Just need this manual if possible
I need Service Manual on Nuwmark TT200, turntable, motor inop, Ic TA7259P need to know the layout, has power supply voltage an regulators seems to be ok, comes on but motor inop.
Thanks David Williams Email davidglenn7@yahoo.com.
Mar 30, 2009 | Numark CDX Turntable
Vestax PMC 05 PRO MIXER master output is not working
More than likely the output PCB might be faulty, or the signal amp might be damaged. In either case, not an easy fix. As for service in the UK, try HARD TO FIND RECORDS - they have a pretty good service dept.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 25, 2008 | Vestax CDX-05 Turntable
Numark CDX CD Turntable
HERE YA GO!! GOOD OLD FASHIONED BEATING FIXED MINE... I PROMISE THIS. When you turn on your CDX... HIT THE SQUARE AREA where the play button and the cue buttons are located. It will jump to CDX on the screen and work fine. Mine did this and i messed around with bumping it and stuff and figured this out
Apr 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Not reading any cd's
they are known for this! Does it take cd in for a few seconds and spit out? Does it take cd in and just tick? (if you put ur ear up to the drive you'll actually hear it try to spin but just give a lil tick noise). Numark does sell a replacement cd drive which isnt exactly a 100% fix but worth a shot seeing how the unit cost quite a bit. If you do end up replacing the cd drive and does not fix your problem there is also an internal cable. Once you pull out the drive, look inside to the left you'll see a white flex cable which may need to be re-seated. Let me know how you make out!
~digitalscorpion
Jan 15, 2008 | Numark CDX Turntable
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
Numark CDX Turntable Logo
267 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Morne Olivier
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
