I have a GE room air conditioner and the digital display that normally shows the room temp now has two letters EP and the air conditioner does not cool. What does the EP stand for and how do I get it back to normal.
  • 3,741 Answers
Following are error display codes for GE airconditioner:---
Display Codes:
E1 or EP error:---- Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.---.
ER error:--- temperature sensor failure. Call for service.
thanks,keep updated and please accept the solution.
Posted on Sep 24, 2009
My ge AEW18DMG1 window unit shows an error code EP. What does it mean?
GE EP code is main compressor sensor.
Check damage to the temperature sensor
Sensor Cable left side yellow.
My airco got visited by a rat and damaged the wiring.
Cut it rejoined and code 32 changed into temperature.
You need the sensor. Just joining the cables will issue 99 and it will cut off and change into 32
You need a working sensor.
Jun 01, 2012 | GE Air Conditioner Main PCB - WJ26X10241
Just installed a GE ajcq12accm1 and it will only cool for about 5 minutes, then blows room temp air ........do you have any tips on fixing this...please ?
Besides calling out a certified ac tech. It may be the t stat set at a higher temp than actually is in room. (Calibration)
May 28, 2012 | GE Built-In Room Air Heat Cool Air...
I get an error code EP on my GE room Air conditioner. what does this mean? i did what someone suggested and unplugged it; replugged it and reset it; still did not work,.
Sep 10, 2010 | GE AJCQ08ACB Air Conditioner
When I cool the room it doesn't drop to the temperature I have it set to but a few degrees celcius higher. Is that normal? I honestly never checked on my old unit but this one doesn't seem to feel as cool.
there is suppose to be 15--20* temp. different on the air supply & return air temp.Over 20* and the coil or the filter is plugged up. Below 13*--anf the unit is not charged properly.
Dec 02, 2009 | GE Quiet-Aire Ductless Split System Air...
Housesitting. RTH111B model. I cannot keep the
That is a NONprogramable T-stat. There is no program to overide, therefore there is no need for a "hold" option. To set the temp, place the switch on the side marked
COOL
OFF
HEAT
to the desired setting, and push the up down arrows on the front until the display shows 80.
The DISPLAY will revert back to the current room temperature within a few seconds, and will keep the unit on until it reaches the desired temp.
The set temperature remains at 80, it just shows the current room temp.
Aug 31, 2009 | Heating & Cooling
What does EP mean on the air conditioner display?
I had this same problem with mine, i unplugged it and pushed the reset button on the side and now it's working fine.
Aug 25, 2009 | GE Heating & Cooling
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
GE AGM08LJG1 window unit: digital temp increases on its own. Ex: when set to 65 degrees (and timer set to turn the unit off in 4 hours), return to the room 2 hrs later and the digital temp reads 69. What...
its telling you the room temp that is been sucked into the evaporator.its normal for this to happen.once you set the temp you want.it stays there untile you change it.but its all good.
Jun 09, 2009 | GE Deluxe AGM08LJ Thru-Wall/Window Air...
No Air
30 is too low. Raise the thermosta to 74 and see what happens
Jun 04, 2008 | GE Built-In Room Air Heat Cool Air...
Heating & Cooling Logo
308 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
