Question about Motorola Mobility RAZR V3
Can't seem to fix the white screen on my LG cell phone
I put my cell phone on a table while i was busy but just in case i have a phone call i can answer it, but when i got to my phone i opened it and realized that all i have is a white screen, i tried taking the battery out, thinking it might fix the problem but it didnt. is there anyway to fix this problem?
  • 101 Answers
It has something to do with a cable that connects from your keypad to the rest of the phone. If you bring this back to the place that you got it at, they should be able to get it fixed.
Thanks
Regards,
Neerak21
Posted on Sep 25, 2009
Panasonic KX-TGD564 Link2cell call forwarding code
Have one of these bluetooth answering systems. they link to your cell phone to allow it to be used on cell headset mode instead of hunting for a handset. Handy but I have gone away from that after a year. The forwarding your are talking about is not initiated from the cell phone (I guess it could be) but from a cordless handset. And if properly paired, why do it? Your cell phone responds to the base and allows all functions. Answer, place calls etc. From the land line not your sell phone.
Mar 08, 2018 | Panasonic Lands Phones
Pls help to write an excel formula to display date, thanks! Cell A1 input a date - 1 Sep 10, Cell B1 write a formula to calculate & display the date which = (A1 + 14 days but if the result is a...
This is too complicated for a help site like this, you are going to want to consult an excel forum, or some excel professional in your area. This is far beyond the scope of what you can expect for $15, which I'm sure you now realize after 10 days of trying.
Thanks
Tim
Sep 26, 2010 | Microsoft Excel for PC
How do i set call forwarding to a cell phone #?
Press Superkey
Press More until the Forwarding softkey appears.
Press the forwarding softkey
press either busy, no answer or always softkey.
if you pressed busy or no answer, press Internal, External, or Both softkey.
Dial the destination number.
Save on or Save off.
press superkey.
Jul 23, 2010 | Mitel Superset 4150 Phone
How can i stop my incoming calls going straight to answer phone
Go to phone settings then call settings, select call divert and make sure its on when busy/unavailable but not all calls. or you can as well put the call divert off.
Jun 04, 2010 | Sony Ericsson K800i Cellular Phone
On our rpe system there are some tables that will not closeout and are showing active for several days the same item(s) ring up at different prices
Sounds like two different problems. The tables not closing out are probably one of two things. The invoice got put on hold or the cashier trying to close the table didn't open the table or doesn't have correct permissions to close table. Worse case scenario is a corrupt entry in database.
Different prices on same item could be someone playing with the special pricing on the item or if you have time based menus setup, they are actually pointing to different items that display the same.
I program rpe menus remotely and could give you a hand. Contact me at sysadmin@ccybernet.com or call 814-226-9612.
Oct 07, 2009 | Pc America Restaurant Pro Express
I dropped my Samsung Instinct in water
dear,
anytime, whenever u face this kind of problem.. immediately remove the battery and let it dry either by itself or put it under lamp at a certain distance..
now do as mentioned.. remove the battery and open the casing if u can and put it under the table lamp (100W) at a distance of 5-6 inch.. and let it there for about 2 hours then try again after confirmation that it is dry by looking keenly..
hope it wil work..
if still not working then it can be the case of circuitry. you will have to go to shop for repairing ....
regards,
hope u understand the matter so dont forget to rate it as it will fix the issue hopefully
Mar 31, 2009 | Samsung Instinct Cell Phone
Cells copies post as bitmap
I think you are referring to 2003 onwards when this problem appears - in which case at the bottom right hand corner of any pasted item is a list of options and buttons which will refer to the table. cells or image being pasted.
Click on the table option to retain your formatting.
Jan 11, 2009 | Microsoft Excel for PC
How we can create Forms & queries in access
For forms, open a data table in view mode, while there locate the forms setup wizard. For your first try just answer the questions the best you can for the wizard. When there are no more questions to answer wizard will create a form for you. From what you learn doing that you may get enough hints to make a form from scratch. Just keep in mind you always build a form from the fields in a table.
Now for the Query, start out the same way and use the wizard. Query to most folks means ask a question and get an answer. In access query is a way to present sub sets of data or ways to modify data in the fields of your tables.
Jun 03, 2008 | Microsoft Computers & Internet
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
