Question about Cobra Microtalk 100 FRS Walkie Talkie Radios 2 Pack
Cant charge i jus bot a cobra microtalk i cant charge it
  • 3 Answers
First confirm the battery is in properly. then your charger should have an output equal to your battery power, e.g. if the battery is 3.6 v make sure your charger is at least putting out that. make sure the contacts on your charger are making contact on your radio.
Posted on Sep 24, 2009
What volt charger is needed for (cobra microtalk pr560wx)? Thanks,Richard
Hi Richard,
Volt Charger??? I'm not sure what you mean, but if you mean what voltage to recharge the batteries, then you need to look at the unit, all over to find the AC input, there should be something tht states voltage and polarity there, if it infact has one.
Pease reply with more detail re: your query.
Regards,
Peter
Jan 20, 2013 | Cobra Ga-cs Or Ga-cl Microtalk Charging...
Need online manual for COBRA microtalk 2way radio
Most of the Cobra product models are here: https://www.cobra.com/pages/manuals.cfm . Scroll down to the MicroTalk Two-way radios/ . The direct link to the manual for the CXT90 is https://www.cobra.com/downloads/manuals/CXT90_MANL.pdf .
I hope this helps.
Oct 06, 2011 | Cobra Electronics microTALK® CXT90 Two...
My cobra microtalk cxt450 will not charge. and the charger lights are not on when i place them in the charger
pull the batteries out, slam them ******* a solid surface. put 'em in, let 'em charge. if that doesn't bring 'em back buy new bats.also, use a voltmeter to make sure the charger was getting voltage.
Sep 04, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I just put new batteries in my Cobra microtalk PR 3500 DX battery charger. How long will it take to charge them? Should the Radio's be in the on or off position. Thank You mjbarry42@comcast.net Mike...
The radios will work fine while being charged, but they will charge faster if turned off. Normal charging time is 8-10 hours, but I would recommend an overnight charge - they won't overcharge or be damaged by the longer charge time.
Bill B.
Nov 05, 2010 | Cobra microTALK PR 3500-2 DX VP 2-Way...
I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
Jul 09, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Microtalks don't seem to charge, even charged many hours
When you say they worked fine for a long time, do you mean a long time as in "hours", or for many months or years? If hours, then remove the batteries and be sure they are in correctly and plug the charger into a different electrical outlet. If the radios have not been used for many months or longer, you probably need to replace the rechargeable battery.
Feb 06, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Microtalks won't charge
I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
The Cobra microTALK PR-3500-2 DX VP Radios are supposed to be equipped with acoustic noise filters that are built in the microphone. This problem could have been caused from the radios getting wet, damaged, or the microphone going bad, the microphone can be replaced if you still have the warranty, but if you want to save money you may wan to get a new set of 2-ways. I suggest the Uniden GMR325-2, these models are inexpensive and have an approximate 5 mile range in good conditions.
Good Luck!
Jul 05, 2008 | Cobra microTALK PR 3500-2 DX VP 2-Way...
Radio Communications Logo
642 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
