Question about Bosch Nexxt WTMC 6300 Electric Dryer
Dryer runs but doesnt heat. Used to just unplug and replug cord and would work but now even that won't work
  • Bosch Master
  • 7,482 Answers
Sounds like you have to replace your thermostats in the back of the dryer. Also check to make sure your heating element is good
Posted on Sep 25, 2009
Few months old WM3987HW won't turn on - seems dead, unplugging and replugging won't work; outlet has power
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Aug 07, 2011 | LG WM3987HW Front Load Washer / Dryer
Runs for little while then stops and has the code PAU on the display. I tried unplugging the cord, I reset the circuit breaker. Still the same and now it won't even start.
Try taking the control board out and check for burned off traces. Solder back those points and it should work again. Just did it to mine and now it runs again. Still flashes PAU though.
Jul 07, 2011 | Kenmore 84072 Electric Dryer
Dryer stop powering on after unplugging the unit and replugging. I got a shock when I did so. Any clue?
Check the back of the dryer where the power cord goes into it and make sure there is not a cut in the cord causing a short, there should be a protective clamp or ring to prevent this from happening but sometime people do not take the time to put them in right. Be careful with it because that is running on 220 and a good shock from that could literelly kill you. So carefully unplug it or better yet turn the breaker off first at the electric panel for it.
Mar 17, 2011 | Whirlpool GEW9868K Electric Dryer
Dryer runs but doesnt dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 19, 2010 | GE DPSB613EDWW Electric Dryer
Dryer runs but doesnt get hot
heatman101
May 12, 2010 | Kenmore 800 7983 Dryer
check the heating element and the limit switches there are the first things to look for when theres no heat
Jan 29, 2009 | Roper REX4634KQ Electric Dryer
Dryer runs intermittently
"Could the cord/plug and/or receptical be bad and need replaced or is it likely to be something in the dryer's internal wiring?"
Yes, that electrical smell and the dryer not working are all signs of a bad motor.
"I noticed that the plug looked like it was somewhat scorched."
I would replace that plug. This is how electrical fires start.
Dec 21, 2008 | Dryers
Copy
- try doing the power cycle.
- unplug the power cord w/o turning off the unit
- wait for about 2 minutes.
- replug the power cord.
- then try to do copy again.
- if still not working, try to press set-up go to tools and clean the printheads. if still not working go to next steps.
- took all the cartirdges out.
- clean the electrical contacts of the cartridges and the carriage with a lint free cloth moisten with an alcohol.
- wait for 30 seconds
- replug the power cord and install the ink cartridges if the printer ask them to install
- try to do a copy
- is still not working
- try to do a reset
- unplug the power cord again
- then press and hold the # and 6 key while the printer is unplug
- and while holding them both replug the power cord
- then do not yet release the two buttons, wait for the printer to start up and if the screen turns off thats the time you will release the two buttons
- then follow the on screen instructions.
Aug 25, 2008 | HP Officejet 6310 All-In-One InkJet...
Bosch Nexxt WTMC 6300 Electric Dryer Logo
128 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
