Question about Riverdeep Mighty Math Cosmic Geometry (1073) for PC, Mac
Write an equation in point slope form of the line that contains the given point and has the given slope. f(6,2), g(2,4)
  • 1 more comment
  • amyburgess
    amyburgess Oct 26, 2017
    you can find help with this task at https://maxhomework.com/. where professionals will help you
  • kasturi kanna
    kasturi kanna Feb 13, 2018
    DD Vs CSK IPL Tickets: After a decade, IPL matches are still being loved by the entire cricket fans despite the fact that lot controversies get widespread across the nation. We all know that the battle between the teams is mainly said to be the IPL season. https://delhidaredevilsipltickets.in/
  • mahresult
    mahresult Apr 12, 2018
    It is the board which was developed in the year of 1966 with 9 divisional boards across the nation in various parts.
    www.mahresult.nic.in
    Brigadier General:
  • 4,090 Answers
Sorry we dont do homework its cheating
Posted on Sep 24, 2009
How to solve and graph the equation 4x+y+0
The easiest way to solve and graph and equation is to put the equation into the slope intercept form y = mx + b, where m is the slope and b in the y-intercept.
To do this, we subtract 4x from both sides and get y = -4x + 0.
From this we know m = -4 (slope) and the y-intercept is 0.
I always start with the y-intercept and put a point there. Thus, we have a point at (0,0). Using this as a starting point, we now use the slope of -4 to get future points. Since it is negative, we go one unit to the left and up four units. So we have the point (-1,4). Using a ruler, we connect these points and continue on both sides to produce the line.
There is also a great free online program/app called Desmos that you can use to check your work. Type in the equation of the line and it will graph it for you.
Good luck,
Paul
Oct 27, 2016 | Office Equipment & Supplies
Write the slope intercept form of the equation of the line through the given point (-2, -3), slope=1/2
The "slope intercept form of the equation of a (the) line" is y=mx+b, where m is the slope of the line and b is the y-intercept.
We are given the slope of 1/2, so m= 1/2.
We can now write y=1/2 x + b.
Since the point (-2,-3) is on the line, we can substitute it in and solve for b. We put the -2 in for x and -3 in for y.
-3 = 1/2(-2) +b
-3 = -1 + b
-3 + 1 = -1 + b +1
-2 =b
Thus, the equation of the line is y= 1/2 x -2
To check if we did this correctly, plug in the point (-2, -3) to see if it works.
Left Side Right Side
-3 = 1/2 (-2) -2
= -1-2
= -3
Feb 24, 2015 | Office Equipment & Supplies
How do you find the slope of an equation?
If your equation can be written in the form of a function (y=f(x)),
the slope of the function at a point is the derivative of the function at the point. For any function that is not a constant or linear, you need calculus to find the slope.
If the function is of the form y= ax +b, the slope is the value a.
Mar 21, 2014 | Texas Instruments TI-84 Plus Calculator
3x+9y=17
  1. Transform this equation to its functional form:
  2. 9y=-3x+17 or y=(-1/3)x+17/9
  3. In the last equation, the slope is the coefficient of x, namely -1/3.
  4. A line parallel to this one must have the same slope (-1/3).
  5. So the equation of your line starts this way: y=(-1/3)x+b.
  6. To identify (calculate) b, you must make use of the fact that the parallel line passes through the point (1,5).
  7. That means that the coordinates of the point (1,5) satisfy the equation of the parallel line y=(-1/3)x+b
  8. Substitute 5 for y, and 1 for x and solve for b.
And that is as far I will go. I leave it to you finish up the work : find b and write the equation in the functional form, then convert it to the general form (Ax+By+C=0) if that is what you are asked to produce.
Aug 05, 2012 | Office Equipment & Supplies
Find the linear equation in slope-intercept form
The equation of a straight line can be cast into several forms: functional form, general form, symmetrical form. The functional form is the one usually known as slope intercept form.
In the functional form, y=ax+b or sometimes y=mx+b, the factor of the x-variable (a or m as the case may be) is the slope of the straight line, and the value b, is the ordinate (y-value) of the point where the straight line cuts (intercepts) the y-axis.
Since you say nothing about the particulars of the line that interests you, there is not much more that anybody can help you with.
Mar 25, 2012 | SoftMath Algebrator - Algebra Homework...
Can i ask how to answer this?2x-4y-9=o
That is an equation describing a straight line. The "slope-intercept" form of a line is
y = mx + b
where m is the slope (change in y-value / change in x-value)
and b is the y-intercept (the point where the line crosses the y-axis when x=0)
Positive slope means the line is rising and negative slope means it's falling.
You can rewrite the original equation 2x - 4y -9 = 0 in slope-intercept form:
y = (1/2)x - (9/4)
So you know the slope is positive 1/2 (line rises 1 y-unit for each 2 x-unit change) and crosses the y-axis at -9/4. With this information you can graph the line.
Jul 12, 2011 | Sewing Machines
Find an equation of the line containing the given pair of points (1,5)and(3,6)
Calculate the slope (gradient) of the line as a=(y2-y1)/(x2-x1) where y2=6, y1=5, x2=3, and x1=1. You should get a=(6-5)/(3-1)=1/2
The equation is y=(1/2)x PLUS b, where b is not known yet.
To find b, substitute the coordinates of one of the points in the equation. Let us do it for (3,6).
The point (3,6) lies on the line, so 6=3/2 PLUS b.
Solve for b: 6 MINUS 3/2=b, or b=9/2=4.5
Equation is thus y=(x/2) PLUS 9/2 =(x PLUS 9)/2
Oct 20, 2010 | Texas Instruments TI-84 Plus Calculator
Find an equation of the line containing the given pair of points (-6,0) and (0,1) what is the equation of the line? y=
Calculate the slope (gradient) of the line as a=(y2-y1)/(x2-x1) where y2=1, y1=0, x2=0, and x1=-6. You should get a=(1-0)/(0-(-6))=1/6
The y-intercept is the y-cordinate for x=0. Its value is 1.
The equation is then y=(x/6) 1.
Oct 18, 2010 | Texas Instruments TI-84 Plus Calculator
Analytic geometry
assuming the question is what is the circle equation?
and if (-2,2) is the center of the circle
the equation should look like this: (x+2)^2+(Y-2)^2=R^2
And now only R is needed.
given 2x-5y+4=0 equation of line perpendicular
we can rearange the equation to be y=(2x+4)/5
from that we can see that the slope of the line is 2/5
And from the fact of perpendicular line we can say that the slope
of the radius line is -2/5.
The motivation now is to calculate the distance between the center of the circle to the cross point of the radius with the line perpendicular
For that we would calculate the radius line equation and compare it to the equation of line perpendicular
As mentioned earlier the slope of the radious line is -2/5.
So the equation is y=-2/5x+b and b can be calculated by using the center of the circle coordinates
2= - (2/5)*(-2)+b ------> b=2-4/5=1.2
radius equation is y=-(2/5)x+1.2
Now the cross point is calculated by comparing the equations:
-(2/5)x+1.2=(2x+4)/5 --> -2x+6=2x+4 --> 4x=2 --> x=1/2 --> y=1
So the cross point is (1/2,1).
The distance between the points is calculated by the following
Formula:
R=SQR(((1/2)-(-2))^2+(2-1)^2)=SQR(2.5^2+1^2)=SQR(6.25+1)=
SQR(7.25)
Therefore the circle eq is (x+2)^2+(Y-2)^2=7.25
Oct 26, 2008 | Casio FX-115ES Scientific Calculator
Riverdeep Mighty Math Cosmic Geometry (1073) for PC, Mac Logo
455 people viewed this question
Top Riverdeep Computers & Internet Experts
Bosse Photos
ray gallant
Are you a Riverdeep Computer and Internet Expert? Answer questions, earn points and help others
