Question about Cameras
Need to reestarlense
Need to restar lense. i can not turn it on . it is a power shot a 480
When I push the power button the lense moves in and out several times then the camera just turns off. I tried charging the battery and holding the power button down for 10 sec. but still does the same...
The power button has two purposes explanable;
1. A firm press and hold would shut down the entire device, where would be common feature for the camera to perform a system check to include the lense functionalilty.
2. A gentle press and release of the same power button should capture a snap shot only after the camera has been powered on, by the similar process as pressing firmly the power button
Remember
Pressing firmly the power button would shut down camera completely after a system check if only the camera was on.
Pressing firmly the power button when the camera is off would turn on the device by performing a system check also.
Important note
The camera when powered on would have an indicator light of ready to capture snap shots.
The camera would autoshut down when left on for an extensive duration without capturing snaps.
The instance of such would generate a camera check once more before powering off completely
The lense adds to the cameras feature capabilities of acquiring images. a function of the lense is capture an impressive image where the mechanism of drawing closer to the object is made possible by a moveable lense. The Olympus FE-340 Digital camera is powered by a battery requiring sufficient energy for a snap shot. keep in mind that, the camera can perform without the lense. However, the device is designed to automatically responded whenever the lense is required.
Important note;
1 a solution to the camera is with the source of energy in which instance batter power.
2.Dislogde the entire power area consisting of battery, check for improper installation; reinstall the battery in appropaitely noticing the installation indications of power supply. Cover the battery compartment properly, and charger afterwords.
Caution
1.Charge the battery for the entire duration known of a full charge.
2.Unplug thereafter when the full charge indicator is visible.
3.Try on the device for improvement in situation by taking photo snap shots
Dec 02, 2010 | Olympus FE-340 Digital Camera
Restar a samsung F 480
you can remove battery and restart. but dont lock ur keypad, u can remove lock code using cable only
Sep 12, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Sony cybershot 7.2 went to shut off camera and lense is still out no power to camera tried to recharge batt. w/no results
Try different batteries. I got the same problem with my cyber-shot. The battery was too low while lense was fully open. I recharged, but the lense would not close. When I turn it on, It would say turn off and on again. I did that for at least 20 times. I finally put another set of batteries and while I turned off the camera, I pressed the lense in very softly. After a couple of times the lense retracted fully. The camera has been working normally ever since.
It is also possible some dirt some how got on the sides of your lense. Try cleaning the sides of the lense.
If you had no luck so far, then your lense may have some mechanical problem. The lense need to be opened and cleaned and put back together.
good luck
Jun 09, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
DSC_W110 model problem
You definitely have some dirt on the outside of your lense. You need to keep it clean by holding cloth on the outside of the lense. Turn the camera off. If the lense does not retract fully, while turning it off, press on the lense (up and down motion with the lense motion) very softly for a few times. The lense should retract 100% inn. If not %100 retreacted, but almost 100% retracted push the lense a little harder in until it retracts all the way in exactly the normal position. That should take care of your problem. Good luck
Jun 09, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Turn power off and on again message
turned camera on and off as instructed and i keep getting that same message. lense cover does not open.
Oct 13, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-Shot DSC S90 lens problem - fix or buy new?
its better to replace a new one than to repair it and besides you will cost alot if you decide to repair it. although if the cost is not that much then go for repairing it.
CHARCOIS
Aug 27, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
8MB SmartMedia Card
Quality Pixel Resolution Storable images TIFF 1600 X 1200 1 shot 1280 X 960 2 shots 1024 X 768 3 shots 640 X 480 8 shots SHQ 1600 X 1200 5 or more shots HQ 1600 X 1200 16 or more shots SQ 1280 X 960 (HIGH) 8 1280 X 960 (NORMAL) 24 1024 X 768 (HIGH) 13 1024 X 768 (NORMAL) 38 640 X 480 (HIGH) 32 640 X 480 (NORMAL) 82
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
