Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
I have a Sony KV36HS420, All was fine when my twleve month old daughter fell all the remote and the TV shut off. I tried powering it back up but when I do it clicks and acts as it is powering up, I hear sound for about 2 seconds, then the unit shuts down. After the the shutdown, the Standby light on the front blinks 7 times. Help me!!!
  • Sony Master
  • 8,457 Answers
Ur high voltage is dead,FBT,flyback trasformer it dead.The big block of plastic with a red wire hook a cap to the CRT(tv ttube).
Posted on Sep 28, 2009
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Unit shutdown immediatly then standby light flashes 7 times
check secondary power supply. check eletrolytic capacitor nearby chopper and regulator
Jun 01, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
We have an RCA flatscreen TV, less than 6 months old, which will come on fine, but then after a minute the picture will go completely out. The audio remains just fine. When we shut down the TV and power...
have you look your sleeping timer on you tv isit on put it off right now if it continue behaveihg like that seek nearest sony daelers immedirtry coz your warrant is okey nice day
Apr 23, 2009 | Sony KV-36XBR400 36" TV
Our daughter gave us a Toshiba TV and remote. We plug in the TV and hook up the cable,and try to turn on the TV but nothing happens. We can turn on the TV with the TV button,and it works fine,but we would...
If the remote is the original Toshiba remote, it obviously should work the TV. Have you checked to make sure it has good batteries? Also, if old batteries leaked in it at any time there may be corrosion on the battery contacts keeping it from working. Make sure the metal contacts look shiny, not crusty and corroded.
If the remote still doesn't work there are two possibilities. One is that the remote is just bad. You can get a universal remote, set it for Toshiba and try it. It will at least control power, channel and volume functions. If the universal remote doesn't work, the remote sensor in the TV would be the probable cause. Like any other part, they can sometimes fail.
Apr 11, 2009 | Toshiba Televison & Video
TV locked with blue screen
Try resetting the TV to factory settings thusly:
Turn on the TV. While holding down the RESET button on the remote
control, press the POWER button on the TV. (The TV will turn itself off, then
back on again.) Release the RESET button.
Owner's manual available here:
http://www.docs.sony.com/reflib/docget.asp?manualid=9635&template_id=1&region_id=1&DL=
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 46" lcd turns off by itself and will not power up again.
Sony TVs come with a one year warranty on parts and labor. Call Sony at 1-800-222-SONY They will find a local company to service this product.
These TVs have a self-diagnostic screen that a tech can access to help solve the problem. Your problem could be any number of things including the fan(s) stopping, the ballast board failing, Q-box issue or none of the above.
michtech
Feb 19, 2009 | Sony Televison & Video
if your tv unit is still under warranty, first you better bring it back again to the store you just bought it for warranty purposes, your tv has an internal problem, maybe manufacturer defect. Usually the cause of that is a shorted electronics component, say for ex, a mosfet transistor that is located at the power section, or maybe a capacitor that is leaky, and also an open resistor. if you don't know how to troubleshoot this problem, you better have your tv unit repaired by a professional tv technician.
Good luck
Jan 22, 2009 | Sony KDL-46S4100 46 in. LCD TV
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
167 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
