Question about Sunbeam 2346 Heritage MixMaster Series Stand Mixer
Sunbeam mixmaster model 2346 won't tilt back out of bowl
  • 4 Answers
SOURCE: Regarding the Sunbeam Mixmaster (model
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Posted on Dec 16, 2008
SOURCE: Sunbeam mixmaster jammed, will not
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
Posted on May 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: Sunbeam Heritage Mixmaster Won't Tilt
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 12, 2009
co7196
  • 3433 Answers
SOURCE: Motor head will not tilt back
but you got it entered. LOL Ok,does the button seem or feel like it is depressing or engaging anything? Unplug the unit and split the shell . The top part should come off. then you can see what is wrong. do not run while disassembled.
Posted on Oct 13, 2009
SOURCE: Sunbeam Mixmaster Heritage model Tilt mechanism
Theory: Its a screw at the joint that is lose.
Problem: If I held mine upside down it released but wouldn't when right side up.
Partial solution (in progress): It took me an hour to disassemble the monster as I lost the "NUT" inside the motor - the nut is inside the motor case and attaches the lock-lever and a ground wire to the motor case. It makes some sense since it is a part that can strip out if it has to be tightened too many times by a gorilla - a nut is "easy" (relatively) to replace. Prevents you from having to buy a new one at least. Wish they would engineer this better.
Current status: I finally fished it out but have to put it back together now to prove my theory. You cant get into the motor case easily - but I found out that you don't have to get into the motor case if the screw is still semi-attached. I only had to undo the the base to get to the hinge. Then I could tighten the screw. I am an AMATURE - so at your won risk. They make these things so you need to send them in. This most likely seems to be what I have to do now.
Posted on Sep 25, 2011
Sunbeam stand mixer won't tilt back down
I'm in the middle of a bake sale. Not a good time to send back. Also, I think you meant a free Upgrade at no additional cost...
Dec 14, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Bowl does not rotate anymore
This is typical of Sunbeam mixers. The solution is to throw that piece of junk out and never buy anything from Sunbeam again. They can't stand behind their products because they know they are junk. They would go out of business if they tried to repair/replace all of the useless appliances they sell.
Oct 24, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Bowl wont rotate
My Sunbeam mixmaster bowl won't turn, how can I fix this?
I believe that this particular model is supposed to have the bowl mix separately. I have removed the black piece from the bottom of the larger bowl in order to allow manual spinning. If I am able to figure out how to fix the bowl spinner I will make another post.
Mar 06, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
Nov 27, 2010 | Sunbeam 2346 Heritage MixMaster Series...
I can't get the tilt release to release to raise the mixer . I have a batch of cookie dough in the bowl and I am unable to raise the mixer
Try running the mixer for a few seconds to clear anything out from under the beaters, like a chocolate chip. You can also try pushing down on the beater end of the mixer, press the button and lift.
Nov 01, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Heritage Mixmaster Won't Tilt back
Hi
Thanks
Rylee
Jun 12, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster jammed, will not tilt back
I hope this helps!
Dec 28, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Mixmaster Heritage series
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Jun 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam 2346 Heritage MixMaster Series Stand Mixer Logo
96 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
