I'm getting a code of f11 on the display panel. could you please give me an idea of what to look for. thank you for your time.
  • 1 more comment
  • Tony Sep 26, 2009
    Sir, I guess computer lost it or I screwed up. It's a Maytag front loader model MFW9700SQ1 The lady said it quit and shows an F11 on the display. she can open the door. If you can give me an idea of what I should look for I would appreciate it. I don't have a list of the diff. codes and their meaning. thank you for help. tony
  • Tony Sep 27, 2009
    Boy it's allways nice to talk to someone who knows what hes talking about. And in your case,You're top shelf pal. Going on the job Mon. and will do as you said. Thank you. I will get back to you and let you know the results.
  • Tony Sep 28, 2009
    Thank you for your help. I odered a new ccu board and I'm sure that's the problem. Your comments are always welcome here. The age of electronics is upon us. Not like the old days, when you got a call and you checked VIO to PK OR TN . thaks you're a good guy.
    President:
  • 1,462 Answers
F11 is a serial communications error that is associated with , central control unit (main computer) or associated wiring and the washer works intermittently . Just to be sure you will need to check all your wiring connections going to the central control unit To access follow these steps:
1. Unplug the washer.
2. Remove the three 7mm screws holding the top panel on. They are located along the top edge in the back of the washer. Once the screws are removed the top panel will slide back then lift up.
3. The Central Control Unit (CCU) is located in the central rear of the washer. You can't miss it. Make sure all the connections are plugged in snugly. Check ONE connection at a time.
After checking wiring harness, run systems diagnostics test by performing the following:
The diagnostics will run through a series of tests to include FILL, AGITATE, DRAIN and SPIN functions. , . You can push PAUSE/CANCEL any time to end diagnostics. Run this test several times. If anything fails you will get an "F" code in the display window. If the tests all pass, the unit will shut off, followed by an audible "beep" and the CLEAN light indicator will be lit. If you get successful results, then you know you probably had a loose wire somewhere. If the test fails, I would attempt to replacet the CCU. The CCU can cost as much as $220 depending on where you get it.
Please leave me comments,if you need furthur assistance, Else please rate this solution
RNJ VINODKUMAR
Posted on Sep 26, 2009
  • Vinod Kumar
    Vinod Kumar Sep 27, 2009
    Thanks for your appreciation, Let me know the result...Waiting to hear from you
  • 284 Answers
Can you tell us the model and make of the washing machine please?
You may just be able to do a google and find your user manual online.
Frigidaire model number FEFL79DSB showing a F11 code on the control panel. Oven will not turn on and I am getting a alarm.
I appreciate your post, Dale Miller!
From what you have described your Frigidaire range is displaying an error code of "F11" and you are receiving an alarm. Normally an "F11" error code stands for a shorted keypad. I would suggest performing a reset and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" error code you may need to replace your control panel. I would recommend having a professional do so, they will be able to properly disassemble your range and accurately replace the electrical component to not damage anything internally on your range. I hope this information is helpful to some degree. -Matt
Feb 28, 2015 | Frigidaire Kitchen Ranges
The electric stove I have is beeping f11 how do I stop it from beeping
I appreciate your inquiry, friend!
I see that you are having a difficult time with your Frigidaire range displaying an "F11" error code. That error code stands for a shorted keypad and I would recommend performing a reset on your range. You can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" code you may need to replace the EOC (Electronic Control Panel) this is not a simple DIY job. I would recommend contacting a professional technician for proper disassembly and repairs to be completed. I hope this is helpful information. -Matt
Feb 25, 2015 | Frigidaire Kitchen Ranges
Power Surge Electrolux double oven EI30EW45JS, now producing F11 code, installed new board, how to reset to see if problem is fixed?
Good Morning Jennifer Lynch, thanks for your post!
I see you have replaced the control board on your Electrolux wall oven and it is displaying an "F11" error code. "F11" stands for a shorted keypad, since you have replaced the board I would recommend resetting your wall oven. You can reset your wall oven by flipping the household circuit breaker off for ten minutes. If you need further assistance please feel free to reconnect. I hope this is helpful. -Matt
Oct 13, 2014 | Electrolux EI30EW45JS | 30" Double Wall...
Have whirlpool duet that kept giving f11 code I replaced front control panel and still giving code. Do I need to reset after installing and how or does problem exist in main computer
This seems to be a communication error and it is possible that there is harness issue from the main panel to the motor panel. remove and reset the connections.
Please check this link for error codes for the machine
Jan 18, 2013 | Washing Machines
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F11 error
Hi
Thanks for using FixYa. Error F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). This usually occurs when CCU goes bad however, to check what has gone bad you’ll need to remove the top panel of the washer and also remove the rear panel to access the drive motor & MCU. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
Error code F11
Try turning off the breaking for 10 minutes that will reset the clock and sometimes fix the problem.
Nov 11, 2008 | Kitchen Ranges
F11 code Whirlpool Duet GHW9300PWO Washer
well your close f11 is a motor control unit error or a loose connection in the wiring harness from the mcu to the motor or from the mcu up to the control panel the mcu is under the bottom kick panel un plug the washer safety first then start at the motor follow the wires back to the mcu checking wires and connectors then form the mcu up to the control board check your motor for continuity normal should be about 6 ohms between pins 1&2 then same at pins 2&3 same at pins 1&3 your motor maybe overheating and tripping out on overload then restarting when the washer motor cools down if all that checks get back with me and we will run diag on it
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
