Question about Meade Optics
How do I adjust the clutch mechanism on an old Meade DS1045. Cloc
How do I adjust the clutch mechanism on an old Meade DS1045 scope. Clock motor won't turn scope. David
  • 3,186 Answers
Contact Meade customer service, and or here are all the Meade manuals:
http://www.meade.com/support/index.html
http://www.meade.com/manuals/index.html
Posted on Sep 26, 2009
Won't turn
There is a separate RA motor and a clutch to turn the scope in synch with earths rotation. Have you turned the lever to engage the clutch ? If not there may be a mechanical problem requiring disassembly to diagnose
Apr 02, 2014 | Meade 60AZ-T Telescope
Ds2130at vertical motor blue print schematic
Only Meade would have this information. Contact their customer service here:
or they have a repair service--but they want the scope returned to them for repair.
Nov 26, 2011 | Meade DS-2060 (175 x 60mm) Telescope
Meade DS 2000 Goto Reflector scope. I am looking for the base goto motor assembly housing witch houses the motor and gears. Can anybody please help?
You cannot actually get parts for this scope other than from Meade directly-- and possibly a USED motor on Ebay. Usually Meade wants you to send in the scope for repair and will not sell you any gears or motors.
www.meade.com
Jun 10, 2011 | Meade DS-2114 ATS (325 x 114mm) Telescope
Hiya Steve here do you know of anyone who can upgrade all the parts in my Meade etx 125 Eg- gears clutches and give it a good service (basically change the plastic bits,and s00p it up!! there is a guy...
Yes, Dr. Clay supercharges ETX scopes--
http://www.arksky.org/supercharge.htm
You can also send them into Meade. Depends on how old it is and what is wrong if they will agree to repair it:
There are some big scope dealers in Europe that also provide this servive if they SELL Meade scopes. Call them.
Jan 17, 2011 | Meade ETX-125AT (500 x 138mm) Telescope
I have a meade lx200gps 10" scope. The ra up is not responing. the down is working only. After initializing and fining north the auto star says stalled motor.
Do a calibrate motors and make sure you are using a separate 12 volt power pack or BRAND NEW internal batteries. All goto scopes work better with smooth, regulated power. The internal batteries will NOT work well for very long.
The Calibrate motors routine adjusts the motors for the power supply being used.
Oct 10, 2010 | Meade LX200GPS Telescope
Motor tries but cannot move on the horizontal. Moves fine on the vertical. Usage only in Alt/Az mode. Only have the electronic controller that came with the scope.
You did tighten the AZ clutch? You did start from the HOME position? (turn the scope Counterclockwise to the hard stop)
Then you will either have to send it back to Meade for repairs, or open the bottom of the base, and look inside and see if the AZ worm gear is actually meshing with the motor. It could have come loose.
Meade customer service:
Oct 08, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
I have a meade lx90 8inch 3 years old with autostar 497--when i try to raise the scope up it keeps drifting down also having problems with intermitant slewing on set up-both motors working ok
This is called "rubber-banding". Your scope needs to be re-trained.
So, setup a target during the day at least 100 feet away from the scope (200 feet would be better, Calibrate motors using the same power source you use at night, and Train Drives. Later after dark, do a Calibrate sensors on Polaris.
You should train drives about once per year, and calibrate sensors about twice per year.
You may want to update the firmware before you Train Drives. The latest version is 43Eg available on the Meade.com web site. You with need the Autostar Updater Software also available on the Meade web site under Customer Service---- Downloads. Version 5.9
www.meade.com
Oct 27, 2009 | Meade LX90 Telescope
Old Meade Polaris - attacking motorized gear boxes
Call Meade and see if they still service this scope.
Jul 12, 2009 | Meade Optics
Locking screw
You will need to check out the clutch mechanism in the fork arm. Refer to this web site for disassembly pictures.
http://jan.eaglecreekobservatory.org/
Look under Declination adjustment link off the main page.
www.scopestuff.com
sells an upgrade clutch kit that improves the clutch. However if something is broken inside then this must be fixed first. Meade will want the scope returned. They usually do not sell parts; but sometimes they do sell them, so call Customer Service here:
Oct 26, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
Optics Logo
192 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
