Question about Hasselblad 40mm f/4 CFE Distagon FLE T Lens
Hasselblad SW/C stuck on 'B'
I have a Hasselblad SW/C that has its speed ring stuck on 'B'. I can't get it to rotate to any other speed. I've had this camera for 10 years and it's the first time this is happening
2 Suggested Answers
SOURCE: Underwater housing parts
Hi this is an old housing you have to make the parts yourself, film advance adapter, it is dificult to make one. But toothed diaphram and focusing ring is easy
Posted on Sep 29, 2010
Badger 5 no good, but can't get it out. tried to turn counterclockwise by the "ears" with screwdriver after WD-40, tried hammer on driver, etc. and still there! Called the co., followed all...
I think you are saying that the Badger is stuck to the sink basket.
So the connector ring will not rotate off.
Open following link for illustration to make sure we are talking about same thing.
http://www.fixya.com/uploads/Howto/geno_3245_1.jpg
Arrows on the illustration point direction for installing new disposal.
So the connector ring goes opposite direction from arrows.
If this is not your problem, then add a comment with in-focus photo of your problem posted on Flickr. You photo will give me clear view of the problem.
The connector ring has 3 metal loops that stick out.
Put short screwdriver on one of the loops and hit screwdriver with a hammer.
I've had them stuck pretty bad, but hammer and screwdriver always worked.
If sink basket starts rotating when you are hitting connector with a hammer, you can cut a stick and jamb it between the bolts and the cabinet.
Once the connector ring comes loose and disposal drops down, loosen the three screws, and there is another clamp ring that holds the sink basket parts together. Clamp ring comes out by prying with screwdriver.
I wrote some tips for putting the disposal back together.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I can't seem to get the knob for film advancing off the camera body
There should be a small slide-switch on the wind knob itself. If you slide it back, the knob will rotate backward slightly and pop off the body.
Jun 15, 2011 | Hasselblad 503CW Medium Format Camera
99 kawasaki kx 125 2-stroke wont start or stay running, but when push started with wide open throttle it willl run and continue to run until throttle is let off or under 1/4 throttle. I've pulled the...
I would check the compression of the piston, the rings could be stuck and not have good compression. It should show 120 psi or more. Also can pull off the exhaust and look in the exhaust port to see the rings, piston, and cylinder walls. If the motor has a power valve make sure that is not gummed up or stuck. Mark C
Jun 02, 2011 | kawasaki KX 125 Motorcycles
I have 400 & 640mm Novoflex lenses latest type I wish to use on Hasselblad 201f (focalplane shutter). First, will these lenses cover the 6X6cm format? Second, what kind of adapter do I need and...
Yes they will. You need a Novoflex HAPRO adapter which can be ordered from your camera store. You may also need a new focus tube if your lens is set up for a 35mm camera as the flange focal length for 35mm is different then for your camera.
May 15, 2011 | Novoflex Hasselblad Lens Adapter Ring Lens...
Put a brand new drive belt on my sony PS-LX250H and the sound
If the belt is installed correctly (around the center ring on the underside of the metal platter & around the motor post), try adjusting the SW screw on the underside of the unit that apparently fine-tune adjusts speed. It fixed the speed on my turntable - more info/instructions on it are posted under Mocamom1's question & solutions regarding PS-LX250H speed adjustment.
May 09, 2009 | Sony PS-LX250H Turntable
I have a dewalt 2 1/4 hp type 1 var speed soft start the magnetic ring broke had it replaced by a dealer still doesnt work i replaced the speed module still nothing sometimes it wants to run it might...
could be brushes stuck, the tubes might have been smashed a little not allowing them to contact the armature or other major electrical problems, Check for continuity thru the brush tubes and see what you get.
Mar 09, 2009 | Dewalt DW618 Router
1,2,4 hasselblad cft* 80mm speeds runs like 1/30
Those speeds tend to hang up from lack of use. You can try exercising them by cycling through the speeds, but it will most likely need service. The lubrication on the gear train has probably dried up, it is a common problem since those speeds aren't normally used.
Sep 28, 2008 | Hasselblad Cameras
Hello Hasselblad -
I have the same housing, and have all of these parts. However, I need to keep them so that I can still operate my rig.
I have a few suggestions:
1) create and save some searches in ebay that will alert you to this stuff when it eventually will surface
2) contact Subaquatic Camera in Salinas, CA. My understanding from one of their techs is that he fabricated at least some of these parts for another client. Perhaps he still has the machining specs and could make them up for you
3) contact me if you need photographs of the parts for purposes of providing to a machine shop to have them made for you (earmstro a t hotmail d o t com)
And for anyone else who has parts for these housings, I am looking for two different parts that go with a SWC camera in this housing:
- the fitting that mounts in the flash shoe, that engages with the front section mechanicals to trip the shutter release
- the film advance adapter for a SWC
I would most like to purchase these parts but if someone can just help me out with photographs (and better yet, dimensions taken with a micrometer), I would be most grateful as that will be enough information to go have the parts I need made.
thanks,
-Eric
Nov 15, 2007 | Hasselblad 501CM Medium Format Camera
Lens not stopping down
sometime it may happen, put the camera body without lens put it on the speed of b see when you klick the camera the shutter will go up and also mirror then the body is ok , put the lens sapratley you will see one small part is over the mount when you rotate it the lens appurture is opened and close u can put the f2.8 the ere is closure of appurture when you move the knob like wise u change the app and vise versa
Feb 09, 2007 | Hasselblad 80mm f/2.8 CFE Lens
Hasselblad 40mm f/4 CFE Distagon FLE T Lens Logo
52 people viewed this question
Top Hasselblad Cameras Experts
Michael Galve
Michael Galve
Allen Showalter
Allen Showalter
Level 1 Expert
Are you a Hasselblad Camera Expert? Answer questions, earn points and help others
