Question about Samsung WF328AAW Front Load Washer
Door will not open, lock will not release - no error codes
Everything lights up has time remaining just makes busing noise? Please advise
  • 1,531 Answers
Buzzing noise would be a stuck drain pump. use a shop vac attach it to the end of the drain hose and remove all the water.then you acn turn the makcine on or unplug it for a few minues then pkug it back in this should unlock the door.once the water is removed, take off the drain hoses to the pump and look in to see what is stopping it from turning.if there is nothing blocking it the pump may be bad
Posted on Sep 26, 2009
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Error code F 9
Hi below is the meaning of the error code and corrective actions needed. To open the door manually take the panel out from under the door and reach up to the door lock mechanism. On the door lock there is a tab, pull the tab and this will release the door. If you have any questions please feel free to ask. Mike
F/09
Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check for Drain Pump Failure
  • Check the Inlet Valve for proper shut off
  • Check the Pressure switch for proper operation
Oct 20, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hoover Nextra HNWF 3135 Door Not Locking
1) since you do not have any error code, because you do not mentione, we must shure you have problem with the switch door, test for open or defective and replace, Test the wires loose, or broken wires.
God bless you
Jun 28, 2012 | Washing Machines
My fuel cover does not lock with central locking
According to WIS, the remote boot release is directly connected to the PSE via CAN
The pneumatic system equipment makes vacuum or pressure available for the following systems:Central locking (CL), (pressure, vacuum)Remote trunk release (RTR), (pressure)- actuation via remote trunk release switch or via radio
AD80.20-P-2002-02B Remote trunk release, general notes on Models 202.01/02/12/12 as of 1.6.97,diagnosis, advanced information, RTR 208, 210 as of 1.3.97, 210.081Actuation of PSE control module:The remote trunk release switch (N72s15) is connected to the PSE control module (combined) (A37) via CAN data buses. The remote trunk release radio signal from the key is conveyed to the overhead control panel control module (N70) via theantenna. This transmits the signal to the electronic ignition switch control module (N73) via CAN data buses. If a valid signal is recognized there the PSE control module (combined) (A37) is actuated via CAN data buses. The remote trunk release IR signal from the key is conveyed to the respective door control module (N69/1, N69/2) via the IR receivers (A26/1, A26/2). This transmits the signal to the electronic ignition switch control module (N73) via CAN data buses. If a valid signal is recognized there the PSE control module (combined) (A37) is actuated via CAN data buses.
If the trunk lid is unlocked the LED in the remote trunk releaseswitch (N72s15) is actuated by the PSE control module (combined)(A37) via CAN data buses.
Special features on model 208.4 (Cabriolet)The trunk lid cannot be released remotely with the transmitter key.The rollover bar (RB)/soft top operation control module (N52)signals via the CAN interior data bus whether the soft top is lockedor unlocked or the power soft top switch (S84) is operated. As long as the CAN message reads:"Power soft top switch (S84) operated" or"soft top unlocked"the trunk lid cannot be released remotely.
Pneumatics testingPermissible leakage in complete system at:vacuum of 300 mbar within 1 minute: 30 mbarPermissible leakage of actuators with lines at:vacuum of 300 mbar within 1 minute: 25 mbar
Thanks
Apr 02, 2012 | 2000 Mercedes-Benz CLK
My washer door is locked. cant open
If the door remains locked and you cannot open it, this could be a momentary program glitch. You can attempt to reset the Central Control Unit (CCU) by unplugging the washer for AT LEAST 30 minutes. If the door still remains locked following a CCU reset, there is a manual release you can use to open the door. The following link explains how to access the release:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
In many cases, operating the manual release will return the door latch to normal operation. If you still experience problems, or have any indications of error codes on the front panel display, please post back and let me know. I hope this helps you.
Jun 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door won't open on Hoover vhd9163zd washing machine
THE DOOR MAY HAVE A TIME RELESE SWITCH CHECK IN MANUAL
Dec 24, 2009 | Washing Machines
I have a Whirlpool WFW9200SQA12. F22 light
"F22" is a Door Lock error code. This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem, however, is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, opne the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door lacth the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistant error is a failed door lacth. If all these preliminary checks are unsuccessful, replace the door latch. The next link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
NOTE: "Fdl" is the same as an "F22" error code. This error code appears on older models.
I hope you find this information helpful. If you have questions please let me know.
Apr 12, 2009 | Whirlpool Washing Machines
Maytag Neptune Front Door Load, Problem
Hello Yery1975
Welcome
You said, you have a situation with my washer machine (Maytag Neptune front loader). It was making the noise several times as latching the door, then if would go off and you could not open the door, You found the under soap deposit cord but the situation is not opening the door or no, it is getting he machine to work. Whichever cycle you press, the door makes the locking noise several times, sometimes the door can not be opened and the lock door light is off, the thing is that whichever cycle you try the numbers on the electronic pad would go down several numbers and then it will again make the door locking noise and will stop there, the start button begins flashing and the machine does not wash at all on any cycle, neither it spins or rinses. Can you please, please, help me? Ohooo... some times after trying and trying get the FL code... you have tried keeping it disconnected from the electricity for long periods, plugging it back and all you can think off.... but nothing!!!
You did the right thing
The Maytag Neptune had a lot of very different defects that Maytag was, and is aware of still.
That is why they discontinued that model .
But if you call Maytag service this time, you may find that it will be one of those defects in their design and an authorized Maytag person will recognize which fault is taking place.
perhaps they may cover the parts if you bring it to their attention.
Thank You
Please remember to leave a rating
Oct 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Samsung WF328AAW Front Load Washer Logo
228 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
